skinneejay
- Sep 4, 2010
- 539
- 22
- 0
Hey I went to install this tonight and had trouble. I wiped system factory reset. Did format system and installed the rom. Got stuck in the boot up. Pulled battery. Restarted. Loaded. My sd card didn't show. Couldn't see my picture in the gallery. Also my android ID was changed. Should I make just wipe data factory reset. Then wipe cache and dalavick? Never got the Android ID error before.
Sent from my Nexus S 4G using Tapatalk 2
I'll try again tonight. This kids is why you always create and Nandroid back up! haha.
Simple restore and you're all good! How's your battery life been?
I use NSTools to set options. Found you need to install, boot to recovery and set permissions. Using AirKernel r1 voodoo only, BLN on, I/O - Sio, Governor - lulzactive 200/800. Inc CPU load 80%, pump up 1 step, pump down 2 steps, screen off min step 5@200mhz. Everything else stock.
