[ROM][July 23, 2012] AOKP Milestone 6 [RC5] AOKP/CM9 [Nightlies]
Status
Not open for further replies.
Re: [ROM][July 23, 2012] AOKP Milestone 6 [RC5] AOKP/CM9 [Nightli
lol im sorry but thats kinda funny. Same thing happened to me last night when i tried.
but didnt you just type that post from a computer?
yea lol...to clarify.. i dont have a good usb that connects to ODIN.. :(
I am not sure whether it had a keyboard or not. I use app2zip which allows me to install my apps from recovery right after I install rom. I would check it or if I were you guys.
sent from my BAD A$$ Epic touch
I'll try this to see if I can get it to work
Sent from my SPH-D710 using Android Central Forums
:) thanks dark but it wouldn't have done me any good.. I have to sign in to AC to view links.. I scoured the internet until I found a link that worked and installed astro file manager then installed the ics keyboard I had in my downloads folder.. only took me all day but I got it :rolleyes:
It was a pain cuz of those stupid sites that use captcha and 4shared I couldn't sign in :(
RC4 to stable 1 will be okay right?
Also, should I backup before I flash or clear data/cache/dalvik, THEN flash?
Curse being a noob :confused:
Sent from my SPH-D710 using Tapatalk 2
Where did u put nova launcher.. so I can delete it :/
I adjusted my LCD density to a lower setting and thought it looked great. It glitched hardcore when I got phone calls and I could not receive them at all so I had to go back to 240. I really liked it though, like someone said before it was almost like a tablet. Any fixes that anyone know about? Sure hope so.
Read the aokp screenshot thread and there is a fix posted.
Thank you def3nder. I am experiencing another problem however and I am not sure what is causing it. I am not getting visual voicemail and the voicemail icon won't go away. It says I have new Mail, when in fact I do not. Anybody have any clue what is causing this?
Which vvm apk. did you flash? Might just delete it, wipe cache/dalvik and reflash.
Now I am having data connectivity problems. I can barely get a data connection and I think it has something to do with the stable 1 I tried to load last night. I am talking horrible connections where I used to have good connections. Maybe I need to flash another kernal? I don't know please help.
Status
r3dpuk3
