[ROM][July 23, 2012] AOKP Milestone 6 [RC5] AOKP/CM9 [Nightlies]
Status
Not open for further replies.
Should I wipe data, cache and dalvik on RC4...or only the later two?
I guess I really don't understand where the GPS firmware/software sits.
Also wiping will not help gps at all.
Sent from my SPH-D710 using Tapatalk 2
Wiping will not solve gps issues...usually lol
I has issues the first time I flashed rc4 so I backed up everything to my laptop and then wiped EVERYTHING, including my SD card. Reflashed, redownloaded all my apps fresh from the market and have had zero issues this time around. Like stated above, try flashing back to GB, get lock, boot into recovery, and reflash aokp.
Sent from my SPH-D710 using Android Central Forums
Reactions: osc006
I'll try that since I wanted to jump to RC5 anyways.
Deakelem you mentioned flashing FF11 then RC5....I can try that too.
That's what I did for rc5 works perfectly now
AWESOME. I like the theatrics lol.
I was gonna stick with rc4 till the official stable build but now I don't know :rolleyes:
This should be 95% stable. Lots of code changes. Upgrades to sensors, gps, ril, build.prop, libs, framework, you name it. Rest assured that ALL my updates are major. I will not release a small one or two change update. Its not worth it. And no changelog to speak of yet. Users can check out the nightly cm9 changelog for all updates. If its needed then I add it.
Reactions: elport
Yea ff18 or ff11 works. Id go with ff18. Odin method works great
Re: [ROM][July 23, 2012] AOKP Milestone 6 [RC5] AOKP/CM9 [Nightli
Pretty much giving up.. This rom just does not work for me, on TWO different phones.. Sleep of death, random reboots and then when I am talking on the phone it starts clicking and reboots right in the middle.. From what I have had the chance to play with, it seems like a cool rom. Thanks anyway..
Hey Dark did you forget to add a keyboard for RC6? After flashing all I have is google voice typing and its making it impossible to get past the gapps initial setup, and also adding my gmail account to access market place to install ics keyboard.
Is this just me?
Thanks man
-Dean
Sry man :( you really are missing out on this badass rom.
Besta luck
No not yet. Just downloaded and waiting for my battery to charge up.
sent from my BAD A$$ Epic touch
Is anyone having issues with connectivity? 3g etc
Could somebody pretty please tell me where in the system I can extract the wallpaper images? I want to use one for my lock screen.
Status
heitezy
