[ROM-July 31]G-T-R Reloaded 7.8.6| Gaming+Beats(Root Fix Updated)
Re: [ROM-July 31]G-T-R Reloaded 7.8.6| Gaming+Beats(Root Fix Upda
Haha, I usually get a day of full use out of this battery and charge it all night. 11-13 hours seems about right.
I'm on phone 95% the time it's not dead. Lol. :p
Got myself a random reboot today. To be fair, the phone was on 5% running an internet-using app on 1 bar of 3g, and was very, very hot...
but it's the only issue I've had since first flash on Saturday.
Also, I have all of my apps linked to my 2nd partition with Link2SD, but I never went into Terminal Emulator before like the OP said... should I be worried?
Nothing's been wrong with the phone yet, except for the reboot I just mentioned, but like I said, I was pushing the poor phone to the limit.
I get reboots when I'm on 3G with all roms. No idea why. It just locks up :(
be sure to stop dsp (if you use it), and google playstore after every boot... otherwise theyll run constantly in the background... cached process'?...
Reactions: inceyet
Everything works perfectly except one minor thing. When I try to listen to long audio files on the internet with either the music or walkman player itll let me listen to about 5 mins of it and close out. Wondering what might be the issue
That happens to me as well, often if I select a song to play and then quickly press the lock button to turn my screen off; it will play a couple seconds of music and then completely exit out
This rom is based on a really old nightly comparing to the recent CM. So... :)
So... :)
I think, when I have some spare time, I'll just flash Ginger Snap. Looks a lot more stable.
Even though I've had zero issues with this ROM.
Bump.
Considering switching to GTR to give it a test.
A small tiny update would be nice :p
Just to sync with the latest cm7:D
Bump.
I did that, and, honestly, I love it. I like the UI alot better than GingerSnap, and this ROM is really stable, smooth, and fast.
In the past 2 and a half weeks since I flashed, I've had 4 random reboots. Once while I was heavily browsing on 1 bar of 3g with the battery at 3%. Understandable!
2 random reboots when I'm in the GOSMS app typing up a text.
1 while browsing the 9gag app.
This is less than what I used to experience in an hour.
I'm stable at 844 MHz-600MHz.
I can squeeze about a day's usage out of the battery.
I love this ROM. That is all.
Re: [ROM-CM7-PORT] G-T-R Reloaded 7.8
I just flashed this "GTR" theme on my Optimus V and I cannot find out how to change my lockscreen to look like the ScreenShots in the OP. The rom screenshots have ICS-like, blue icons & unlock buttons, but i don't see any way to change mine to that in this rom after flashing it. Do I need to download something else to do that?
Why is my wifi not turning on???
---------- Post Merged at 10:34 PM ---------- Previous Post was at 10:34 PM ----------
WHY IS MY WIFI NOT TURNING ON???
Is there any way I could get my hands on the GTR Wallpapers apk?
I love them so much, I want them on other ROMs, too :)
First off just have to say AWESOME ROM!! I actually switched from AOKP ICS for this one :) I just had a couple of questions:
1. I keep getting a play market error 942 when I try to download some apps any theories?
2. I am using AS2SDGUI app to move my dalvlik cache to my sd ext 2GB partiton and was wondering if I needed to install scripts for that.
3. I keep getting a system force close at startup any suggestions?
r3dpuk3
