[ROM-July 31]G-T-R Reloaded 7.8.6| Gaming+Beats(Root Fix Updated)
Great rom but was wondering where the gtr wallpaper app was to delete I have two young kids who play with my phone and a couple wallpapers on there I'd like to get off phone
Probably in /system
Sent from my LS670 using Android Central Forums
@TGL. Anyway I can get my mic on the phone to work while regular headphones are plugged in. Like for phone, tango, etc? As soon as my ear buds are plugged in the phones mic stops working.
Re: [ROM-July 31]G-T-R Reloaded 7.8.6| Gaming+Beats(Root Fix Upda
No idea. I have it too. But, I have a mic extension that came with 5 dollar headphones. :)
@ Other Guy, MMS should work just fine. Maybe you have bad reception.
Reactions: adamhos
*drools*
I should be getting a new phone soon, so all I'll need the Optimus for will be music and gaming.
This ROM seems to be just the ticket.
Brilliant!! Can't wait to get it all up and running!! :D
I love it, but I keyboard lag is quite annoying.
Normally I wouldn't post this many consecutive comments in a thread, but this time I really need help. How can I get v6 and kak working on my phone? I need a specific noob-proof guide to make the most out of this spectacular ROM.
Thanks in advance!
Use the default Stock Gingerbread keyboard. Check the thread, theres a Stock Keyboard zip. Ill post a link if i have time.
Thanks in advance!
Open up Terminal Emulator:
Su
V6
Let it run, and use option 7, I believe or one if your choice. Then reboot, that handles V6
Go back in Terminal and do:
Su
Kak
And follow the commands. Its self explanatory :)
Su
V6
Su
Kak
Thanks, the keyboard lag was my fault, though, I type so fast, when I have vibration on, the vibrations can't keep up with me! So, it seemed like lag, so I turned off vibration keyboard and all was well. Yay :)
And, is BusyBox required to run kak and v6???
Thanks in advance.
Busybox is really confusing me. I downloaded the app from the Play Store, clicked "install" and waited and went into Terminal and did the "updatebb" but it said not found... o_O
Su
V6
Su
Kak
When you say check the thread, do you mean this thread or the gingerbread keyboard thread? Because I experience a slight lag and it annoys me
I'm pretty sure I got the link off of this thread, I don't remember, but I have it!
My noob mind is still stuck on Busybox D:
Flash this: http://www.mediafire.com/?67ydb625xxnx3ui
The ICS keyboard takes up ram. A lot of it.
Busybox, is it not working? :confused:
I tried to click install, it says it installed, but in terminal emulator when I say updatebb and it said not found.. :/
I just ended up doing it without busybox and I don't see a difference....
I know there was some discussion of WiFi issues earlier in this thread, but my current one seemed unique so I figured I would ask. When I flashed the rom, I had no trouble getting on wifi - worked perfectly. Yesterday, because I was out and my battery was getting drained, I turned off wifi. When I got home, I couldn't turn it back on. In the settings menu, when I hit the button to check "wifi on", it sits there and does nothing, eventually saying "error" below the box where it normally says "connecting..." or "connected".
I reflashed yesterday and wifi worked perfectly, but I turned it off again today to see what would happen and it does the exact same thing.
If it helps, I did try the 3g tweak but I don't know if that would affect the wi-fi. Again, I am having no problem finding the wifi signal - I just can't even get the phone to turn wifi on.
Thanks for any help.
Thanks! I was just about to do 3g lol.
I just did the v6 without busybox and I haven't noticed difference, probably because I didn't use busybox! Lol :p
I love this ROM, it's my daily. No issues as of 48 hours from flash.
I also forgot to use terminal emulator before using Link2SD.. and now all of my apps are linked......
Everything force closed but I rebooted and now everything's fine.
What are the best settings to get the best battery life out of this ROM? So far mine has lasted 11 hours till I had to charge it. Can I do better?
This is what I have as well. Don't let the last charging part fool ya :P.
To get more, well, use it less ;)
annahernandez51
