good to see the thread is still going, testing RC1 now.
thanks again for the hard work DK
Where'd you find that? I don't see it on XDA.
Calk was a great dev for this device.However,his zip can be found over on xda just search for it. Once you find it,flash it. It pretty much does all the wiping and system and data formatting for you.
I'm looking for the newest modem, not the format_all zip. FG20 is the newest modem on XDA.
Just look a little harder. I promise its there. In fact heres proof.
n00b here, what is calks format and how do you perform that step you described with it? I get the rest. Thanks!
here's the modem for those having trouble locating it on XDA
Boost...?
Haha just found it as links were posted. Thanks all.
DK I truly appreciate how dedicated you are to putting out great content. You have released fix after fix relentlessly. Keep it up man. A lot of people complain about the bugs, but they come with the territory. I bet once all the kinks are ironed out they come crawling back over here
Yeah Boost but it works on Sprint (and works well I might add)
I can flash from any recovery, right? I'm still on AOKP (ICS) now, I've been flashing modems in the included recovery without issue.
Times_infinity claims its safe. I still highly recommend odining to EL26 w/ CWM5 recovery.
Removed The FG series modems please.
Sextape asked NOBODY post links to the FG Series leaks. Period. He not creating any drama.
Rc1 is amazing. No Los and no major battery drain. Deep sleep working as well. Also, for people flashing constantly trying to get this to perform exceptionally, here's what I did. I wiped data, cache, and dalvik regular in el26 recovery. Then I flashed calks format 2 times zip two times. Then wiped cache and dalvik once more then flashed Rom and gapps. After those I once again wiped cache and dalvik and voila! Let it reboot and enjoy.
