[ROM][KANG][08/05/12]CM10 Release Canidiate 1
Status
Not open for further replies.
How long is the logcat supposed to take? It seems like once I started it, its like a live logcat, I think its run for 5 minutes.. supposed to take that long?
sj
Sent with my Epic 4G Touch on CM9-8/06 @ 128 dpi using Tap@Talk Pro v2.2.4
I am receiving LoS. I have service then it drops. I was able to get service indoors no prob, but now have to go outside, reboot or shutdown phone and then service will come back.
I saw some mention of a different modem FG31. Where do I get this? Looked around, but haven't found a download yet. I am also using gapps-jb-20120717-signed.zip.
Thanks for all the great work DK and everyone involved!
Can anyone else back up the claim that LOS is resolved? I was running 1.4, and as soon as I flashed 1.5 I had no service whatsoever. Might just be me though. Rebooting didn't fix it either.
Ran logcat -s CameraHolder and this is what it came up with when i opened the camera.
u0_a34@android:/ $ export PATH=/data/local/bin:$PATH
u0_a34@android:/ $ su
u0_a34@android:/ # logcat -s CameraHolder
--------- beginning of /dev/log/main
--------- beginning of /dev/log/system
V/CameraHolder( 4175): open camera 0
E/CameraHolder( 4175): fail to connect Camera
E/CameraHolder( 4175): java.lang.RuntimeException: Fail to connect to camera service
E/CameraHolder( 4175): at android.hardware.Camera.native_setup(Native Method)
E/CameraHolder( 4175): at android.hardware.Camera.(Camera.java:323)
E/CameraHolder( 4175): at android.hardware.Camera.open(Camera.java:283)
E/CameraHolder( 4175): at com.android.camera.CameraManager.cameraOpen(CameraManager.java:224)
E/CameraHolder( 4175): at com.android.camera.CameraHolder.open(CameraHolder.java:151)
E/CameraHolder( 4175): at com.android.camera.Util.openCamera(Util.java:293)
E/CameraHolder( 4175): at com.android.camera.Camera$CameraStartUpThread.run(Camera.java:284)
V/CameraHolder( 7547): open camera 0 E/CameraHolder( 7547): fail to connect Camera
E/CameraHolder( 7547): java.lang.RuntimeException: Fail to connect to camera service
E/CameraHolder( 7547): at android.hardware.Camera.native_setup(Native Method)
E/CameraHolder( 7547): at android.hardware.Camera.(Camera.java:323)
E/CameraHolder( 7547): at android.hardware.Camera.open(Camera.java:283)
E/CameraHolder( 7547): at com.android.camera.CameraManager.cameraOpen(CameraManager.java:224)
E/CameraHolder( 7547): at com.android.camera.CameraHolder.open(CameraHolder.java:151)
E/CameraHolder( 7547): at com.android.camera.Util.openCamera(Util.java:293)
E/CameraHolder( 7547): at com.android.camera.Camera$CameraStartUpThread.run(Camera.java:284)
Sent from my SPH-D710 using Android Central Forums
V/CameraHolder( 3619): open camera 0
E/CameraService( 1848): CameraService::connect X (pid 3619) rejected (invalid cameraId 0).
E/CameraHolder( 3619): fail to connect Camera
E/CameraHolder( 3619): java.lang.RuntimeException: Fail to connect to camera service
E/CameraHolder( 3619): at android.hardware.Camera.native_setup(Native Method)
E/CameraHolder( 3619): at android.hardware.Camera.<init>(Camera.java:323)
E/CameraHolder( 3619): at android.hardware.Camera.open(Camera.java:283)
E/CameraHolder( 3619): at com.android.camera.CameraManager.cameraOpen(Camera Manager.java:224)
E/CameraHolder( 3619): at com.android.camera.CameraHolder.open(CameraHolder. java:151)
E/CameraHolder( 3619): at com.android.camera.Util.openCamera(Util.java:293)
E/CameraHolder( 3619): at com.android.camera.Camera$CameraStartUpThread.run( Camera.java:284)
So far I've only been losing data sometimes when turning off wifi. Still able to make texts. Never make calls so i can't confirm that one.
Just flashed RC1.5 and no LoS yet! I am going out tonight and won't be connected to my airave or WiFi. Will report if anything happens when I come back later tonight! Thanks again DK for an excellent "buttery" rom!
Because I added in all the CM Tweaks. I was researching other cm10 builds and the camera is a known issue on 99% of them.
Nice, glad you got it figured out! Once the camera is worked out I'm going to jump on this again. Based on all you've done, I am so happy I got rid of my 3D for the E4GT!
Thanks Bro,
Tee Jay
Something that I haven't noticed anyone post is that the audio out via the headphone jack is very low and also the phone does not work with the Samsung Vehicle Dock, which enables audio through the USB port. Has anyone had any experience with this to compare?
Status
gaganprasad
