[ROM][KANG][08/05/12]CM10 Release Canidiate 1
Status
Not open for further replies.
Something that I haven't noticed anyone post is that the audio out via the headphone jack is very low and also the phone does not work with the Samsung Vehicle Dock, which enables audio through the USB port. Has anyone had any experience with this to compare?
You gotta be on a TouchWiz Based Rom. That is a TW only feature
Yes I can confirm the audio out. I use pandora at work, and at the highest point it is like medium on even dk's kang ics. Also, flashed 1.5 about 2 hours ago and still getting los.
Thanks dk for all your hard work.:p
It worked on CM9. From what I've understood, it's kernel related. Some hacked out Samsung kernels would even allow audio from the dialer out (which the stock one doesn't), but I wasn't going to sacrifice stability for that feature.
Torch isn't working either. Going in to it, it looks like it's already on (light bulb is lit). I know it was working before all this, since my toddler likes to throw things in small dark spaces. Glad to see it looks like you figured out the cause for the problems though. I looked on some other devices running CM10 and noticed a lot of the same thing; CameraHolder errors when getting the cannot connect to camera. Some seem to have fixed it by replacing /system/lib and /system/bin files.
well if the camera relates directly to the cm customizations, strip the code from just the cm stuff and try and see where they interfere with the camera. If the camera is a problem in all other cm10 builds for other phones, it probably is just a piece of coding that the cyanogenmod team missed that interferes with the camera (unless im just ranting and you already know all this)
or better yet, if nothing interferes with the camera, check to see if adding the cm stuff takes anything away from what was there before
On RC1.5 with FG20 modem with the gapps that's linked in the OP and have had phone on for over 3hrs and NO LOS. anyone else having the same luck with the same modem?
Sent from my SPH-D710 using Tapatalk 2
Sent from my SPH-D710 with CM10 RC1.5 using Tapatalk 2.
Status
Mohinder02
