[ROM][KANG][08/05/12]CM10 Release Canidiate 1
Status
Not open for further replies.
Re: [ROM][PORT][JB][07/29/12]CyanogenMod 10 [Alpha 4]
So maybe they thought they solved the bricking issue with the kernel but they really didnt? Thats really scary.
Yeah I am not a noob to flashing and I know I did everything right... oh well these things happen... lol and my phone is just a week old :)
I would always suggest using el26 cwm. I've never run into a single issue going from cm9 to cm10 or anything else for that matter. Seems like a safe bet.
Sent from my SPH-D710 using Android Central Forums
Well I just got a brick... using 41g-CWM-RC1-b3-0723 ... telling my story so others can watch out... followed directions in OP to the letter and still a brick :'(
That's strange, i just used the same one. Flashed the .zip through cm9 recovery. The only thing i did different from the OP was flash calks format_all_2_times, then cleared everything manually after that. No brick for me. Needless to say i was giddy as a schoolboy when it booted. What could be the cause of these bricks?
It looks like wiping data inside a aosp/ics recovery. Calks format all script is safe form of wiping cause it uses a GB Update Binary. Users need to not manually wipe data in ics recovery.
Reactions: tamathdb
IF ANYONE USES CWM6 THEN USE THE RC2_5 CWM6! Although i would recommend using el26 to be safe. CWM6 has been pretty sketchy in my experience with it.
Reactions: krazy_smokealot
Next update will use a GB Update Binary. We will see how it works out.
Hope I shed some light on any problems with that. Thanks for all your hard work! It's ridiculously amazing how much you've gotten accomplished since everyone got their hands on that kernel!
Chris41g. Darchstar. And Sfhub are the experts on this Emmc lockup bug. Ill do my best to make it safe.
Using CWM6, not TWRP, follow instructions to the T, and you will NOT brick. If you do, it's your fault. There are very odd chances hundreds of people do it successfully and 1 doesn't.
So I hate to be the one to ask, but with the directions, is the sd card the internal memory?
Just Odin EL26+CWM5 guys. It barely adds any time to the process. Play it safe for now until more is known. Might help to PM sfhub and Entropy too to see if they can drop in, download the files and see where the offending function may be.
Sent from my SPH-D710 using Tapatalk 2
ok ive read the post and cant find the answer...but following the directions from op..i need to flash chris41g's Clockworkmod 5 EL26 Recovery Kernel....so i went here Goo.im Downloads - Browsing Kernel
which one do i use?
well thanks..can someone post a link to the kernel i need to use? i just got my new phone in the mail today (insurance claim) so its not even rooted yet. i have the gapps file and alpha 4 already on my desktop ready to be transferd to my ext sd. i just need the kernel now right?
Updated to alpha 4 for US Cellular ... If you use GB Binaries would that fix anything that is broken, or does that just make it less likely to cause a brick?
Status
Tiokujha
