[ROM][KANG][08/05/12]CM10 Release Canidiate 1
Status
Not open for further replies.
For one person yes but most of us no. That one person simply flashed and it worked. They never did a codec update either.
Sent from my SPH-D710 using Tapatalk 2
Other than YouTube Pandora endlessly skips tracks and won't play anything and I still get a voicemail notification that won't go away.
Try and use an earlier version of Pandora.
Re: [ROM][PORT][JB][07/29/12]CyanogenMod 10 [Alpha 4]
well on A4 i had no sound i use the sound xml file and still didnt get it fixed going to odin el29 stock rooted and see whats up....
Re: [ROM][PORT][JB][07/30/12]CyanogenMod 10 [Alpha 6]
Do we know what the problem is with Google Now? It might be a stretch but has anyone tried going through the steps to install google now on ics to get it working on jb? i.e. download the ics version of the apk, and use it to replace the quick search box apk in system / app, or is the setup totally different on ics? I just took a look at my nexus 7 and the app is still titled quicksearchbox.apk
Anyhow, I had to revert to ds2's equally impressive aokp for stability for the moment, but I'm curious to see if this would work.
Here's a link to the instructions
I wanna wait to see if YouTube works before I flash again your doing great work with this port by the way very fast at responding to issues.. Unfortunately YouTube is a deal breaker for me as I post and watch a lot of videos.. Keep up the great work Dark!!!
Sent from my SPH-D710 using Xparent ICS Tapatalk 2
No reports come on guys lol I guess I'll have to flash and report back
Any idea why i would get status 7 error on alpha 6. using the right kernel to flash.
Thats cause I made all there phones hard brick. Mahahahahah :thumbup::D:beer:
Im just messing around. :p
How I picture what you look like now. Hahaha
Install Failed.
forrmat() expects 4 args. got 5.
E:Error in /sdcard/10_20120730_Darkknight_Alpha6.zip
(Status 7)
Installation aborted.
I dunno why YouTube works for me... I followed the instructions in op. I used Odin on my laptop to flash the kernel.I duno if that made a difference...I get sound but no matter if I go to YouTube.com or use the app..the video looks discolored and grainy on bottom 3rd of video.. flash videos work perfect though...I have the VM indicator that won't go away... still never figured out how to turn on GPS..so I can't check that..where do I find the GPS on button?
Can anyone get me an md5 on a6 and the gapps. I'm DLing via Sprint and would like to check it before flashing.
Thanks so much!
That's what i got, on 2 different downloads.
I'm pretty sure Dark_Knight2 is looking into as we speak. But for now, I recommend that all users download his Alpha 4 until he is ready to release his Alpha 7. :cool:
Status
Tiokujha
