[ROM][KANG][08/05/12]CM10 Release Canidiate 1
Status
Not open for further replies.
Re: [ROM][Jellybean][07/31/12]CyanogenMod 10 [Beta 2]
Try tele nav that worked for me over Google navigation idk worth a try
Never tried that, but I've always had better luck with Waze than Google Maps
Sent from my SPH-D710 using Xparent ICS Tapatalk 2
Did you all try beta 2 with low rider gapps its great!!
In beta 2 does the 3g/data still randomly shut off??
Sent from my SPH-D710 using Android Central Forums
Mine did once since flashing, and 3g seems to be quite slow but other than that very smooth
I keep seeing new updates, and I want to flash so bad, can't wait for you to get everything worked out like deep sleep so I can flash this
I can also confirm that SU is working. And 3G. However, 3G is rather slow.
I haven't had any random reboots so far in the past 2 hours.
Hi thank you for this. I was wondering if anybody knows how to download Beta 2 I click on the link and it brings me to the 4share site. I then hit the link in the tags section and it will bring me to the actual 4share sight and says no matches found for this search. PLEASE HELP :'(:'(:'(:'(:'(
Just had a deep sleep shut off and a few random reboots. Also, keep getting dumped of 4G.
my sentiments exactly and thanks again for all the awesome hard work. this is fantastic!
@Dark_Knight2
Bugs i found: Settings>storage> unfortunately settings have stopped
Google Now worked 1 time now it says unfortunately google search has stopped
other than that it works well. A little more stability would be nice. Thanks for all your hard work! Waiting anxiously for Beta 3.
You need to register to be able to download files from there.
Okay with the el29 lock I got a gps lock within 40 meters extremely accurate in maps gps navigation is still not working
Sent from my SPH-D710 using Tapatalk 2
Dark - any idea why my USCC edits lead to Unfortunately, the process com.android.phone as stopped?
I've edited the build.prop like the ones nothingbloom was editing, but still running into that issue.
Can someone please give me the link to Sbrissens port?
I just flashed Beta 2 with low rider gapps and everything is working amazing. In fact more than amazing. I've never gotten better 3g speeds where I'm living. It's almost like this ROM helped my roaming. Moreover, voice search works wonderfully as mentioned before and butter...is well epic
Reactions: Dark_Knight2
Been waiting to flash this rom for a while.. waiting for my laptop to get fixed.. I need it just in case I mess something up..lol one more week.. :mad:
I had beta 1 installed yesterday and I work third shift so I tested it all night. With beta 1 3g randomly went out constantly all night. My phone lased 6 hours only because during my 1 hour break I charged my phone in my car the whole break. Plus gps did not pick up any satellites using both gps test and gps status and toolbar apps. SU wasn't working for roam control either.
I just installed beta 2 with lowrider gapps 5.4. 3g seems stable so far (only been a hour) and 4g is working great. I flashed el29 first and got a gps lock but gps is still picking up 0 satellites. Once again SU is not working when it comes to roam control. It keeps saying, "Verify your phone is rooted." Also my phone is randomly turning on every few minutes. I installed BetterBatteryStats to see what is causing this wake/lock. I will have more of an update on battery life tommorow after my shift tonight.
Dark Knight your build is going real good and you are real close to a DD. Thanks for your effort and good luck.
Re: [ROM][PORT][JB][07/31/12]CyanogenMod 10 [Beta 2]
I didn't know that it had been released so recently, how was it on Beta 1?
Sucked. I watched the percentage tick away like seconds. 1-2% drain per hour. Supposedly is better now though. Still too early for an accurate assessment.
Get a lock in GB
Flash beta 2 with darks gapps
A lot more stable than low rider (I've tried both) GPS locks within 40 meters. :)
Status
SADdfgf4567
