[ROM][KANG][08/05/12]CM10 Release Canidiate 1
Status
Not open for further replies.
Re: [ROM][Jellybean][07/31/12]CyanogenMod 10 [Beta 2]
Get a lock in GB
Flash beta 2 with darks gapps
A lot more stable than low rider (I've tried both) GPS locks within 40 meters. :)
Sent from my SPH-D710 using Tapatalk 2
Wow I wouldn't think that Gapp zips would make a difference on gps performance. I'll try that method tomorrow after work. I think I might try to get a few hour nap in though. But, testing is so addicting right now. Damn you JellyBean! I'll sleep when I die.
2 quick cm10 general questions, are there toggles in the notification bar, is there a battery percentage option? thanks
Seems like some progress has been made since last night can't wait to get home and hook my us cell brothers up with their first taste of beta 2. Do we have any idea why you can't set up Google now yet dark?
Also anyone confirm Bluetooth media is working??
btmedia not working on my end
phone runs very hot! no pun
Also - chris41g kernel is NOT working with beta2
Enjoying Pandora on beta 2 :) (a little slow to start but smooth now)
About to test battery life
Things I've noticed thus far -
bluetooth media - not working
phone runs hot - expected
when in call - earpiece audio very low (could be modem issue, idk)
nova launcher - crashing
wakelocks - nuffsaid
I'm using nova with no issues phone cools down if you do a few normal battery tweaks (setcpu, soft keys off, brightness lowered, no vibration ect)
Mine runs stable at 35-38c not bad at all!
About the GPS lock from GB, do I have to do that every time I update the JB rom?
Status
websitedesig102
