[ROM][KANG][08/05/12]CM10 Release Canidiate 1
Status
Not open for further replies.
Re: [ROM][Jellybean][07/31/12]CyanogenMod 10 [Beta 2]
do you have a logcat for the crash of google now? do you need one?
logcat
E/AndroidRuntime( 9081): FATAL EXCEPTION: main E/AndroidRuntime( 9081): java.lang.RuntimeException: Unable to create applicatio n com.google.android.velvet.VelvetApplication: java.lang.IllegalArgumentExceptio n: requested provider network doesn't exisit E/AndroidRuntime( 9081): at android.app.ActivityThread.handleBindApplicat ion(ActivityThread.java:4154) E/AndroidRuntime( 9081): at android.app.ActivityThread.access$1300(Activi tyThread.java:130) E/AndroidRuntime( 9081): at android.app.ActivityThread$H.handleMessage(Ac tivityThread.java:1255) E/AndroidRuntime( 9081): at android.os.Handler.dispatchMessage(Handler.ja va:99) E/AndroidRuntime( 9081): at android.os.Looper.loop(Looper.java:137) E/AndroidRuntime( 9081): at android.app.ActivityThread.main(ActivityThrea d.java:4745) E/AndroidRuntime( 9081): at java.lang.reflect.Method.invokeNative(Native Method) E/AndroidRuntime( 9081): at java.lang.reflect.Method.invoke(Method.java:5 11) E/AndroidRuntime( 9081): at com.android.internal.os.ZygoteInit$MethodAndA rgsCaller.run(ZygoteInit.java:786) E/AndroidRuntime( 9081): at com.android.internal.os.ZygoteInit.main(Zygot eInit.java:553) E/AndroidRuntime( 9081): at dalvik.system.NativeStart.main(Native Method) E/AndroidRuntime( 9081): Caused by: java.lang.IllegalArgumentException: requeste d provider network doesn't exisit E/AndroidRuntime( 9081): at android.os.Parcel.readException(Parcel.java:1 429) E/AndroidRuntime( 9081): at android.os.Parcel.readException(Parcel.java:1 379) E/AndroidRuntime( 9081): at android.location.ILocationManager$Stub$Proxy. requestLocationUpdates(ILocationManager.java:646) E/AndroidRuntime( 9081): at android.location.LocationManager._requestLoca tionUpdates(LocationManager.java:660) E/AndroidRuntime( 9081): at android.location.LocationManager.requestLocat ionUpdates(LocationManager.java:482) E/AndroidRuntime( 9081): at com.google.android.apps.sidekick.inject.Syste mLocationManagerInjectable.requestLocationUpdates(SystemLocationManagerInjectabl e.java:33) E/AndroidRuntime( 9081): at com.google.android.apps.sidekick.LocationOrac leImpl.registerForAndroidNlpFix(LocationOracleImpl.java:495) E/AndroidRuntime( 9081): at com.google.android.apps.sidekick.LocationOrac leImpl.start(LocationOracleImpl.java:139) E/AndroidRuntime( 9081): at com.google.android.velvet.VelvetApplication.s tartTgServices(VelvetApplication.java:175) E/AndroidRuntime( 9081): at com.google.android.velvet.VelvetApplication.o nCreate(VelvetApplication.java:108) E/AndroidRuntime( 9081): at android.app.Instrumentation.callApplicationOn Create(Instrumentation.java:999) E/AndroidRuntime( 9081): at android.app.ActivityThread.handleBindApplicat ion(ActivityThread.java:4151) E/AndroidRuntime( 9081): ... 10 more I/Process ( 9081): Sending signal. PID: 9081 SIG: 9 I/ActivityManager( 2084): Process com.google.android.googlequicksearchbox (pid 9 081) has died. W/ActivityManager( 2084): Service crashed 2 times, stopping: ServiceRecord{419c2 840 com.google.android.googlequicksearchbox/com.google.android.apps.sidekick.Tra fficIntentService}
logcat for google now crash
Attention: I just want to make something clear. The word "Dev" or "Developer" has been applied to me by numerious individuals. Trust me. I am not a developer. In fact very far from it. Im a contributor. Nothing more. I just love android. Im just sharing my little knowledge with the community. Nothing more. :)
Don't be so modest. Porting is a form of development. Whether it is worth the title or not is all subjective.
We could just call you Supreme Contributor or Sphen then :p
Hey.. just a thought about the google now... My friend has a working JB build for his Asus Prime, when he gets into a fresh build and goes into the voice settings, the english us file is not automatically there he has to download it... maybe there is something to that?
His works just fine and it is not built from source... ive seen what the google now is actually supposed to do once you click im in... :)
again noticing a FC of google search when going through settings-> language and input -> voice search
according to my logcat, an error is caused by java.lang.IllegalArgumentException: requested provider network doesn't exisit
does the gps work fine with the asus prime build?
yeah it does it is a quite stable release actually and is forced to run at 60fps and can oc on the fly.... it is sweet as hell
I have had a hunch that the google now problem might be a location issue
Maybe it was setup for the nexus... so maybe some nexus things have to be injected.
On a lighter note, I just got my bricked mesmerize (confirmed by the company) brought back to life with odin and stock files i found.... wooot! 3 months later and the thing is back!
Select the "maybe later" option when Google Now tries to run its setup and then it works fine with no FC. Must use stock keyboard though. I have no GPS fix, cannot make calls at all and when trying to make a call its impossible to hang up it just stays in the notification drawer. But thanks a lot for all your efforts, everyone in the community is benefitting from your love of Android.
Google now works if u use low rider gapps 5.4...
Sent from my SPH-D710 using Xparent ICS Tapatalk 2
First of all, amazing port! Loving the overall smoothness. It's great to have Jellybean on this baby.
My issue: I seem to lose over signal after 30 minutes to an hour of booting/rebooting my device. Could you help me resolve this issue? Thanks again for the awesome work.
no it doesnt... try going into settings and set it up click "im in" and i bet it fc's come on people read the threads.... it is still broken technically because it cannot be setup properly.
that is what i am trying to figure out
Status
sellhousefastmke
