[ROM][KANG][08/05/12]CM10 Release Canidiate 1
Status
Not open for further replies.
Clearwire 4G sucks sooooooo bad :( upload failed at 69% :banghead:
That's the same technology sprint uses for their wimax lol take your time bro don't rush it out. Its nice to see you working so hard tho!
Sent from my EPIC 4G Touch!
Re: [ROM][Jellybean][07/31/12]CyanogenMod 10 [Beta 2]
anyone wanna try this?
•Download LennoxPackage.zip from LennoxPackage.zip from post # 2370.
• Extract all 3 folders from LennoxPackage.zip to a new folder on your computer
•Then download and replace the Velvet file in the app folder of your new folder with Velvet.apk from post # 2425 link Velvet2.apk
• Move the folder you've created (with 3 subfolders) to your SD Card
• On your phone, in /system/app/, rename GoogleQuickSearchBox.apk to GoogleQuickSearchBox.apk.bak using Root Browser (or something similar)
•In the folder you placed on your SD - you'll need to move everything from the /app/ folder to /system/app/, and set permissions to RW/R/R for each of the 3 .apks
•copy the files from the lib folder on your SD, and paste to system/lib (note, a couple of these already exist. Before copying these files go through /system/lib/ and rename any existing files to include .bak, then copy/paste new files. If you don't do this it will paste them with '- copy' as part of the file name). Change permissions of these New files to rw/r/r
• rename the existing "config" folder in /system/usr/srec/ on your phone to "config.bak", then just paste "config" and "en-US" from the srec folder on your SD to /system/usr/srec/. I also changed permissions on config and en-US to RWX/RX/RX
•Reboot and enjoy.
I did that with CM9 and everything works BUT the voice talk back. So since that works in CM10 you could be onto something.
Sent from my SPH-D710 using Tapatalk 2
I will have to try it on the morning on my way to bed. If not one has tried it when I get up I'll do it at work.
too tired, i know i did something wrong... someone with fresh eyes can try it, i need sleep.
?Download LennoxPackage.zip from LennoxPackage.zip from post # 2370.
? Extract all 3 folders from LennoxPackage.zip to a new folder on your computer
?Then download and replace the Velvet file in the app folder of your new folder with Velvet.apk from post # 2425 link Velvet2.apk
? Move the folder you've created (with 3 subfolders) to your SD Card
? On your phone, in /system/app/, rename GoogleQuickSearchBox.apk to GoogleQuickSearchBox.apk.bak using Root Browser (or something similar)
?In the folder you placed on your SD - you'll need to move everything from the /app/ folder to /system/app/, and set permissions to RW/R/R for each of the 3 .apks
?copy the files from the lib folder on your SD, and paste to system/lib (note, a couple of these already exist. Before copying these files go through /system/lib/ and rename any existing files to include .bak, then copy/paste new files. If you don't do this it will paste them with '- copy' as part of the file name). Change permissions of these New files to rw/r/r
? rename the existing "config" folder in /system/usr/srec/ on your phone to "config.bak", then just paste "config" and "en-US" from the srec folder on your SD to /system/usr/srec/. I also changed permissions on config and en-US to RWX/RX/RX
?Reboot and enjoy.
working on it
Status
mrtalha
