[ROM][KANG][08/05/12]CM10 Release Canidiate 1
Status
Not open for further replies.
No LOS so far after kernel update on FF18 :)
How should I apply the modified kernel zip file? What method did you use if you don't mind me asking?
Never mind.. and please excuse my laziness to have not read the new posts in the thread. Carry on.
Format all/wipe cache/dalvik
ROM
Low rider gapps 5.4.1
wipe cache/dalvik
flashed modem
Reboot
I was already using the rom prior to kernel update. So when that came i just reboot into recovery
Wipe cache/ dalvik
Flashed updated kernel
Reboot
What's the difference between low riders and the regular gapps ??
Sent from my SPH-D710 using Android Central Forums
Same here. No calls and radio signal is very weak even when I'm in a known 4G area. I have to keep refreshing signal with Network Booster. I love this Rom, but for now, I'm gonna have to flash back to ICS.
I dont understand what you guys are doing differently... never los ever in 2 years being on us cellular. Phone calls, texts work flawlessly... puzzled:what:
Sent from my SCH-R760 using Android Central Forums
Re: [ROM][Jellybean][08/02/12]CyanogenMod 10 [Beta 3]
Taking the plunge now. Have not flashed since the first publicly available alpha. If the LoS and wake issues are fixed.... XOXOXOXOXOXOXO and <3
oh and SU :P
Reactions: Dark_Knight2
I know I said I was going to report back at 1 but I had something to do, BUT, I haven't had no errors, what-so-ever while using your modded kernel. No LOS, no wakes, expect for the DF, which was solved by using a different usb port. I can personally say, that this ROM should be ready for RC status. :)
oh and SU :P
It should most all be fixed now. Everyone on XDA are all complaining of LOS. Lol. They are missing out :D
No harm , but they those members can stay where they are at.
Also, only issue I just realized is battery temperature, but it might just be because of this case I have on the phone. :)
I have that issue on FF18. just set gov to interactive and max freq 1ghz and min freq to 200mhz
Re: [ROM][JB][08/03/12]CM10/AOSP Hybrid [Beta 4]
maybe a dumb question but if I'm updating from beta 3 to beta 4 do I still need to wipe data or can I just wipe cache and dalvik?
You can do that but i dont know how stable it will be. plz dont report any issues til you do a full wipe
So you can flash JB to JB? Meaning I don't have to Odin back to GB first? I can just wipe everything and flash the ROM and GAPPS?
Status
SubnetMask
