[ROM][KANG][08/05/12]CM10 Release Canidiate 1
Status
Not open for further replies.
Re: [ROM][JB][08/03/12]CyanogenMod 10 [Beta 4]
Hey Dark, even though it would be a shame to lose, can you make a version of gapps that doesn't include google now for us to test? Not sure if that is possible but I was reading that google now could be the heart of the problem.
Reading that on XDA now...
Hey just a thought but after wiping and flaahing the rom try booting fully into the ROM before flashing gapps.
Sent from my SCH-R760 using Android Central Forums
Solid yes, some slight glitches to report sometimes out of nowhere my phone will lock up, sometimes it reboots. All things I could care less about.
OK, I have been testing without gapps for an hour now. Unfortunately, while I did not get one single "screen-on", the phone did not enter deep sleep at all. So the deep sleep thing has nothing to do with gapps, it is somewhere in the rom. The "screen-on", however, is definitely gapps.
Reactions: patrao_n
What the hell... why? Android OS is too high man... what are you doing differently besides being on sprint?
Absolutely nothing at all. I've just been letting my phone sit there.
Ran without gapps, and wake locks were gone. But I'm still not getting deep sleep. Even with gapps I cannot get deep sleep. Also, with gapps I get wake locks. But at least I can make calls now!
Sent from my SPH-D710 using Tapatalk 2
you did a good job with this rom so far but we dont have root access from in side the rom could u pls fix
I assume you flashed dk gapps. RooT is there - it's just not prompting for root access. Search this thread and it's been answered.
May be helpful to add this to the OP, just to avoid questions (I had the same question :) )
Reactions: Downtown Taco
Has anybody tried just booting into safemode? I'm doing that now. Will report back...
Edit: That was fast. LOS in about 5 minutes.
it seems some devices can tolerate JB and others cant. Why Idk.
OK so I just removed Google Now from Gapps (I think lol). Flashing now.
I don't think it's the hardware as much as either possibly the way that the modem is interacting with the OS and/or the signal that the user is receiving and how often the transceiver has to poll for towers. I would argue that all the devices likely have the LOS bug, but certain scenarios are exacerbating the problem and making it more obvious.
I unpacked it and removed the apks and then zipped it back up.
got LOS twice so far on beta 4 but everything else is running nice
OK, it is NOT google now. I flashed gapps with it removed and screen is coming back on constantly.
I think I just discovered that if you enable airplane mode, the screen doesn't wake back up. Can somebody else please confirm this??
It has seemed to me that when the screen is waking up, I have service...when it stops. LOS...could be a coincidence, but I'm watching for it. I believe the two issues are interrelated.
Hey guys, I'm green as grass when it comes to flashing, I keep getting system 7 errors when i try to flash any rom, not just CM10, but CM9 as well, could anyone help me out? I can't seem to find any information on it online :( Here is some of my info:
Baseband version:
S:D710.10 S.EL29
Kernel Version:
2.6.35.7-SPH-D710.EL29-CL852097
Build number:
GINGERBREAD.EL29
Hardware Version:
D710.10
Any and all help is appreciated
Status
JanetTheGreat
