[ROM][KANG][08/05/12]CM10 Release Canidiate 1
Status
Not open for further replies.
Maybe, but I kind of doubt it's related to wifi. Toggling airplane mode typically doesn't resolve LOS. It requires restarting the entire radio daemon, which is what that LOS script did. Also, back in the "LOS days", I recall that is was pretty common for people on AirRaves for whatever reason.
Sent from my SPH-D710 using Tapatalk 2
Actually toggling airplane mode does indeed fix it for me the majority of the time. Hmm...
Sent from my SPH-D710 using Android Central Forums
Oh man I thought I had hope
There's hope! Dude, the XDA JB ROM was useless to me with LOS every 2 minutes. I ran B4 Fri night and Sat and I had LOS probably every 10 min. With RC 1, I'm averaging once an hour or so. I have 2 LOS's on WiFi almost within minutes of turning on Wi-Fi, and only 1 LOS probably within an hour of WiFi off. This is HUGE progress for a weekend. DK is accelerating progress on this ROM at a pace that I've never seen before. I'll be honest, I saw he blew through Alphas and went to Betas and said "this is hype...this guy clearly doesn't understand development cycles", but after trying his ROM and seeing DK's progress 1st hand, it's remarkable. There's your hope!!!
Flashed RC1 with new gapps, got this when I went to play store (does for all apps):
Could not download due to an error retrieving information from server. [RPC: AEC:0]
Not sure what to do from here o_o anyone having similar problem?
EDIT: Nevermind, did a factory reset and wiped cache. Working now.
Please help I keep getting status 7 error some symlinks failed i'm on el29 I do everything it says I used calk zip to erase, the flash x2 regular wipe not all on the same try but please help
CM10 Jellybean for the Epic Touch 4G is officially here. As of BETA 3 this rom is now a source built ROM and no longer a port. This is now a Release Canidiate ROM. If you are looking for full stability, this ROM is NOT for you.
This ROM has been downloaded over 20,000 times From Alpha 1 to RC1. That is a huge number. Thanks for the support.
Attention: I just want to make something very clear. The word "Dev" or "Developer" has been applied to me by numerious individuals. Trust me I am not a developer. In fact very far from it. Im a contributor. Nothing more. I just love android sharing my little knowledge with the community. :)
Disclaimer: FLASH AT YOUR OWN RISK. IF YOU BRICK YOUR DEVICE FLASHING THIS THEN OH WELL FOR YOU. I MIGHT EVEN LAUGH. THIS IS FOR ADVANCED USERS ONLY. BY DOWNLOADING FROM THE LINK YOU AGREE THAT YOU AND YOU ALONE ARE RESPONIBLE FOR ANY BRICKED DEVICES.
Source from here and here
My Github: Currently Private, Do NOT PM me about it.
About GPL and Source code:
Android Source Code falls under Apache Licensing and not GPL.
Kernel source does fall under GPL, however my modified code DOES NOT fall under GPL due to it being a modification of already available source code. Go here for unmodified Source code.
Donation Link:
PAYPAL DONATION LINK
What works?
It boots
Touchscreen
Jellybean Launcher
Butter Smoothness
Camera
Video Recording
WiFi
Scrolling
Samsung RIL
3G
4G WiMax
MMS
Google Search
Email
Exchange
Texting
SD Card
eMMC
Reduced LoS (RC1)
GOOGLE NOW WORKS 100%
Bluetooth Calling and Pairing
What doesnt work?
1. Bluetooth Media (JB Issue)
2. Random LOS (Kernel Issue)
3. Wake Locks (Google Services Framework issue)(Gapps)
Everything that is not in "whats working?" section...
Do you got a possible fix or trick to help a fellow user?
Go here to spread the word
WARNING: DO NOT I REPEAT DO NOT FLASH THIS ROM INSIDE ANY ICS BASED RECOVERY. IF YOU DO YOU WILL BRICK. APPARENTLY THE REAL CAUSE OF THE HARD BRICK IS STILL UNKNOWN. YOU HAVE BEEN WARNED.
Directions To Install:
Download CM10 ROM
Download Jellybean Gapps
Mobile Odin or CWM flash chris41g's Clockworkmod 5 EL26 Recovery Kernel (DO NOT USE ANY ICS RECOVERY OR YOU WILL HARD BRICK)
Move both ROM and Gapps to SD Card (If you dont do this you WILL BRICK)
Boot into EL26 CWM 5 Recovery
Make a nandroid of your current Setup inside recovery
Wipe data
Wipe cache
Wipe Dalvik Cache
Flash CM10 ROM
Flash Jellybean Gapps
Reboot out of recovery
Let sit for 5 mins
Enjoy JB
CREDITS:
Sbrissen (Cyanogen/AOSP Maintainer and Awesome Developer)(Huge Thanks)(Kernel)
Chris41g (Cyanogen Maintainer)
Xboxfanj (Epic 4G Source)
Darchstar (Cyanogen Maintainer)
Shabbypeguin (Unofficial Nightlies Maintainer)
Team Cyanogenmod (The whole team)
Team Kang (AOKP Jellybean Pieces)
Samsung (Device)
Google (Making Jellybean Open Source)
DOWNLOADS ARE HERE:
Attention U.S Cellular Users:
Go here to Download A Compatible CM10 test build for your device
SPRINT USERS:
CM10 RC's and Stable Releases:
CM10 RC1 Release keys
CM10 RC1 Mirror
New As Of Aug 05, 2012 at 6:52am Pacific Standard Time
Jellybean Gapps Download here
Changelog:
CM10 RC1 Release Changelog:
Reduced LoS (Better then before)
Reduced Battery Drain (Better then before)
Added New Build.prop Tweaks
Recompiled and Recoded Sbrissens JB Kernel (Developers: STOP ASKING FOR MY SOURCE CODE)
Added Extended Power Menu (Sbrissens Source code)(Huge Thanks)
Added In CM10 Theme Chooser
Added Some New Upstream Fixes (CM10 Source)
Fixed Sleep of Death
Fixed SU and Superuser (Chainsfire)
Reverted to old 07-17-2012 gapps
WARNING: THERE IS ALWAYS RISK OF BRICKING WITH A NEW OS UPDATE. JELLYBEAN HAS BEEN A TOUGH NUT TO CRACK THUS FAR. PLEASE USE CAUTION.
Please hit my thanks button or donate to the open source cause if you enjoy my contribution to this community.
Oh trust me. I understand development cycles perfectly. All my alpha beta and rc build fit perfect with the titles :P
LOS WiFi off again. Enabling data roaming and system select to Auto. Anybody notice the "Radio" options under "advanced" in the system menu...?
EDIT: and immediate LOS after changing settings.
oh trust me. I understand development cycles perfectly. All my alpha beta and rc build fit perfect with the titles :p
i know you will have all the kinks worked out within a week seeming how far you have come with this rom i have alot of faith in you keep up the good work bro
the LoS when changing those roaming settings happens on ff18. Its normal.
I sent DK a pm but he never got back to me (probably have a lot to sort through) so I'll ask here. Can I Mobile Odin to stock EL29 so I can flash AOKP or CM9? I know I can Mobile Odin the EL26 kernel but I don't wanna just flash from the JB recovery to a GB ROM, don't wanna risk the brick.
So in short, can I flash the stock ROM .zip file through MO? Thanks in advance.
Sent from my EPIC 4G Touch!
Reflashed back to stock. (After a wipe) Believe changing settings screwed the ROM up...
EDIT: and still LOS.
What I've been doing is MO stock cwm5 el26, then reboot in to recovery and flash the CM9 ROM.
Not really the answer you are looking for I'm guessing, but maybe you can use it for reassurance.
LOS is constant. Battery drain is not AS bad. But LOS needs to not be marked as "reduced..."
Status
ecomranx07
