JayWill
- Jun 21, 2011
- 2,631
- 571
- 0
I sent DK a pm but he never got back to me (probably have a lot to sort through) so I'll ask here. Can I Mobile Odin to stock EL29 so I can flash AOKP or CM9? I know I can Mobile Odin the EL26 kernel but I don't wanna just flash from the JB recovery to a GB ROM, don't wanna risk the brick.
So in short, can I flash the stock ROM .zip file through MO? Thanks in advance.
Sent from my EPIC 4G Touch!
Don't take this personally, as it's not necessarily directed at you, but ...
GUYS! IF YOU DO NOT UNDERSTAND THE BASICS OF FLASHING AND WORKING WITH ODIN AND CWM ON THIS PARTICULAR PHONE, I HIGHLY RECOMMEND NOT MESSING AROUND WITH EXPERIMENTAL ROMS UNTIL YOU DO!
With that out of the way, here's your answer ...
Just get all the files for the ROM you want to move to onto your phone, then Mobile Odin the EL26 kernel/recovery and use that recovery to flash wherever you're going. If you have issues getting the files onto your phone on the JB ROM, Odin the EL29 One-Click, install CWM and flash from there.
