[ROM+Kernel] MiRaGe-CM7.2-IHO (07132013)
Re: [ROM+Kernel] MiRaGe-CM7.2-IHO
What you have is the default look of CM7 and it does not bother me. Actually, I had to check if my dialer is the same with your screenshots.
Am I correct in assuming that the "dialer" with the black background is actually part of the contacts app and it just passes (among other things perhaps) the phone number to the actual dialer app to initiate the call?
The dialer is inside Phone.apk. But yes Contacts and Phone apks work together.
Just got this text anyone know what it is
//ANDROID://ANDROID:Provisioning successful CFGv320c.0=07cvC/01P8r//CM
I've run every rom, from quattrimus to magpie to backside ect., and I honestly feel this mirage rom is the total package. It allows me to overclock to 806, versus the usual 748, while still being incredibly stable. I can use any app that I have and it just works. Its like there's a split sec. of lag that's cut off from every function. Absolutely amazing :thumbup:
Reactions: mrg666
Thank you mrg666 for maintaining this ROM for so long. Awhile back I moved on to the Galaxy Nexus but my family still uses the OV. I had to do a full wipe of the phone today because some how it was completely locked up after bootup. I found there are still updates to this and was quite happy to say the least.
Reactions: mrg666
Thanks. I am also moving to Galaxy Nexus soon. Are you using stock ICS? I will use GNex with stock for a while before starting to build. But I will keep MiRaGe for OV maintained since we have more OVs at home.
Could be outside the kernel as I posted earlier ... looking into both possibilities.
ive kind of been thinking about this a little. could it be something in the apk itself. im no expert whatsoever on decompiling apps and reading their code, but is it a possibilty
No need to decompile. All of the source is available for the camera app, OS, and kernel. Otherwise, I have never decompiled anything either.
do you think the problem could be in the code?
I have the Verizon Galaxy Nexus running Slim 4.0.
Not sure if this is something you can fix but it seems to be a bug.
I have the notifications bar with the screen lock setting option.
Whenever I turn off screen lock using that and then restart my phone the screen lock turns back on but it will say it's off in the bar.
I am looking into this and will post here when I can find a permanent solution. Since quick reboot does not reboot the kernel, I am thinking the fix could be in the Android OS. It would be great if you know and post a link to any discussion about such a problem in another CM7 system.
I know it's a little late and maybe not what you're looking for but I found this topic in the BACKside Thread. http://forums.androidcentral.com/op...organs-unofficial-cm7-1-a-61.html#post1211699
Reactions: mrg666
Thanks for the link. I remember that discussion. Now that we know the trigger (just plug and unplug a headphone), I think I have found the problem location in the kernel source in arch/arm/mach-msm. I am trying to pinpoint the bug. The other option is to try backporting the relevant part of the code from LGE's latest kernel hoping that the problem is resolved there. But there are considerable changes in the API that doesn't allow simple drop-in replacements. I will post the result here soon.
Reactions: glarepate
Any chance you might build from ICS for the OV in the furture?
I have tried ICS on OV both in the past and recently. But instead of enjoying the superiority of ICS, I felt inadequacy of OV. With ICS, my lovely OV feels lowly :) So I will retire my OV with CM7.
Thanks for all the hard work mrg, I really enjoyed this rom. I'm moving to the triumph and I've swapped everything to it, this is the last post from my ov, posting over wifi. Again, thanks.
sent from my icy cold optimus using inverted T.T.2
Reactions: mrg666
Tiokujha
