[ROM+Kernel] MiRaGe-CM7.2-IHO (07132013)
Re: [ROM+Kernel] MiRaGe-CM7.2-IHO
I was thinking there used to be a feature where you could swipe the status bar to adjust the brightness on this rom. Is that gone?
No, still available and can be enabled via:
Settings>CyanogenMod settings>Interface>Status bar tweaks>Status bar brightness control (checked)
Under the status bar brightness control mine reads that automatic brightness is enabled, but greyed out. Great rom btw!
Not sure if this is applicable, but you might take a read of this MRG reply to a seemingly related issue I'd experienced earlier:
http://forums.androidcentral.com/op...m-kernel-mirage-cm7-2-iho-18.html#post1960209
HTH...
Reactions: dfunk44 and mrg666
great job on the rom. im glad your still updating for gingerbread. i don't think i want to use ics on this phone. i like speed and battery life. thanks mrg666!
Reactions: mrg666
Thank you for your hard work with this rom. I've been using Quattrimus AOKP nightlies but I just switched back to MiRaGe because I got tired of finding my phone frozen in some kind of off state. If I'm reading the first post right... the EGL drivers are now applied? Just want to know if I still should flash the VM670_eglpatch.zip with your rom.
Reactions: mrg666
EGL patch is merged in the ROM. You don't need to flash it separately.
Reactions: ThatGuyLurkin
EXTREME USE on recent release. Music, texting, downloading, phone calls, browsing, and more!
Well ima try that setting. Because 122-806 interactive drains my battery really fast.
The minimum should be 480, setting it any lower is a waste since 480 drains the same amount of battery. Correct me if I'm wrong
Sent from my LG-E739 using Tapatalk 2
MRG was recommending 122-whatever using his kernel specifically with the interactive governor.
What I've found is that I have an older V, when it just came out, and while others can overclock high numbers I seem to be able to underclock and rum smooth w longer battery life.
thats placebo.. tests show that overclocking this phone improves battery life, so underclocking would have a negative affect. it takes the cpu longer to process things, therefore killing more battery.
Unless the kernel has defined voltage preferences depending on clock-speed.
I have my CPU minimal set at 122 mhz and I've been noticing a longer battery life, to the point where my last full battery cycle(Full to dead) lasted 3 days without powering off the device at all.(This includes, Phone calls, txt, sms/mms, 3g data, wifi data, music, and youtube)
Point still being, voltage on these phones are controlled via kernel.
Reactions: jto101680
marywilliams
