[ROM] [LGL55C/OptimusQ] [AreaRom] AreaRomQ v2.0
If your batt is draining in an hour on a fresh flash with 3g enabled, you may want to replace your batt or seak a replacement phone. That's not normal at all.
Sent from my LGL55C using Tapatalk
Good (kind of) to hear. From searching forums/google about the Slider's battery life, I gathered that it was normal... I've put a ticket into Virgin Mobile, and will try to remember to follow up here for future Google search queries...
My phone was at 100 % at 2:00 pm it is now 11:53 pm and it's at 47% I have been listing to music most of the day with out plugging it in. 3g and Wi-Fi have been on as well. (Just so you have an idea on what the battery life should be)
Sent from my LG Optimus Slider (AreaROM 2.0)
My phones older and I've damaged some cells in the battery. I need a new battery but I'm still getting a full day charge with normal usage.
just flashed arearom 2.1 and whenever i connect the usb cable the phone goes the lg startup screen and cannot be used. happens if i connect to computer or power supply.
this is a question first off i just flashed this rom on my optimus slider and i love it the only fault i see is that my physical menu and home buttons are reversed (home is menu and menu is home) any way to fix this other than that love the rom
I flashed this rom on my optimus slider all works fine after i flashed gingerkernal over top but it still says wrong model of phone in about phone area.Anyone know how to fix that?
- - - Updated - - -
i fixed previous issue by flashing gingerkernal over top
PLEASE HELP! i followed these steps exactly, i reloaded my phone and when the lg image came up it stayed there another restart got me to the tracfone splash then it was stuck again. i rebooted in recovery and did a system restore now im stuck in fastboot mode. is this a permanent brick or is there a possible solution here?
Read the OP, it's only for Net 10, Straight Talk, and with the proper kernel Virgin Mobile. You'll have to flash a compatible Rom through recovery
If you can't get to your recovery follow these steps: {pending till I get to a computer}
Sent from my One S using Tapatalk 2
Sorry, I don't much experience with the slider, but does this rom work on the slider? Or would there be a button remapping issue? Thanks!
PS: I do have lots of android experience with my Nexus One and Samsung Infuse so feel free to be technical
Tfunz
