Rom manager problems
Kushling920
9
When I try installing clockwork recovery it only gives me the option to select optimus c and since I installed mirage I can't flash another Rom??
Just because ROM Manager doesn't provide you with more options to flash doesn't mean that is the end of the line for you. Those are only the ROMs that ROM Manager "supports or recognizes".
You can still download a ROM manually and place it on your SD CARD. Then from ROM Manager you would choose Install ROM from SD CARD and it will give you the option to install whatever ROM's, themes, mods, etc.. on your sdcard regardless if ROM Manager officially supports them or not.
yes i understand that and i have tried many times to flash a new rom i have never had problems before until i installed mirage rom now when i flash the new rom iho jeeryscript i get E:cant open/sdcard/download/backside-iho-vm67012212011-1.zip(bad)
then it wont let me use the recovery menu i have to do a battery pull and it restarts me with a clean wipe of mirage
Have you verified the md5 on the file to ensure it is correct?
Have you tried flashing through recovery?
Rom Manager is more trouble than it's worth.
I did flash through recovery I also couldn't flash Aphrodite so now I erased and formatted my SD card reinstalled cwm recovery and will give it another shot after I download again
mostafamu
