- Nov 25, 2010
- 15,958
- 2,753
- 0
That's what I thought.
I read and followed Paul's instructions as stated above.
I was on DK28. I had downloaded EB13 but hadn't done anything with it yet.
Should that be in Odin somplace?
I put EB13 Tar in Pda, nothing happened. Then I added Victory 8G Pit file to pit. Ran and completed, then went to Root
So after reading instructions again, I must have missed doing the modem.
And I just got lights on to download screen, but computer is not showing phone.
I can try Odin, would you verify what goes where or do I do something with Modem first.
If this works, I will thank you as many times as possible!!!!!!
Try removing the battery and leave it out. Then connect to your phone to your computer via cable and try to boot into download mode and run odin without the battery. Also no pit file is needed for eb13. You can also try removing your SD card too, that is an old trick from months back...
Edit: the tar file for eb13 had the modem included so its an all in one package.
