[ROM] NewROM2.1 Updated 1/25/12 Now with Pictures!
Does your Rom work with Version 2.2.3, FB01? I have installed CM01 and flashed the almost stock smoke 1.2 Kernel, but it is soooo close to stock only difference I notice is that I now have it rooted.
I am at work at the moment. I haven't messed with anything on this ROM in a while. I know that there was an ota update fairly recently. I have not checked to see what has changed. I will look into it tonight when I get home.
Sent from my PG86100 using Tapatalk 2
awesome...Thanks! I did remove the 2 files from that recent update that tell it to overwrite custom recovery.
. /system/recovery-from-boot.p
/system/etc/install_recovery.sh
I wouldn't recommend trying it at the moment. My wife is using my old Intercept temporarily until I replace her lost Evo. Therefore I am not able to test it. If you are feeling adventurous you could give it a try. Honesty though, I would look to see if there are any other ROMs built on the new base.
As of now I have no intentions of doing anymore updates for the Intercept.
Sorry I couldn't be of more assistance.
Dont think I will try it then, man this sucks I cant find anything for the 2.2.3. Thanks anyway, if you hear of any thing please let me know.
What are you looking for in the ROM?
permenant root, all the pre loaded bull%$#^ gone, performance tweaked. Nothing majorly over-clocked just a nice performance boost. I think i need to re-flash the smoke 1.2 because I dont have root access.
Well I decided to try your ROM anyways. Unfortunatley it has a constant FC. android.process.acore keeps stopping unexpectedly.:(
Yeah, that makes sense considering it is a different Android version.
ksothpaw9
