Super Nexus!!!
Sent from my SCH-I535 running CM10![]()
You have the circle mod on cm10?...you just flash the zip?
Sent from my SCH-I535 using Android Central Forums
Its in the settings, system settings. Its been in the ROM since after, well I found it on build 11-03.
Edit ....settings,system, status bar,battery
The auto correct for keyboard is not working for GS3 Verizon. Im on the newest stable CM10. any one else having this issue?
Just downloaded cm10.0.0. Change log says its the first one for this device. How old is it? Is it the M3?
Sent from my SCH-I535 using Tapatalk 2
It came out this morning idk if it is considered m3 or not. This is the first labeled stable build. I thought the last two milestone builds were plenty stable though
I was thinking about trying that package. I tried the camera by itself when they first came out with a zip for it. It was pretty cool. I was thinking about trying Google Wallet also. There is a thread over at xda just for Google Wallet for are phone.
This one includes the new Google wallet gmail camera etc....I think the official one will have the new notification quick settings in the notification tray plus the lock screen widgets unless that is just for tablets I'm not sure
Oh, I didn't know that. Its a hole gapps replacement then? Meaning you could replace it with the gapps we have been using?
I think you still have to edit the build prop for wallet to work though.?..
I appreciate it but I'm good. I'm gonna wait and see what happens with CM10.1 or (4.2). Hope it will all be there with that.
