[ROM] Official CM10 Nightlies on your GS3!
Ehhhhh. Yeah. Tw ROM. Beanstock. So I have to flash the stock rooted rom then backup my imei from there?
FissionMailed from N7
That's what I ended up doing. I wasn't running a ROM but had deleted a bunch of crap from my phone after I rooted. Didn't work until I flashed the stock, rooted image in Odin.
Sent from my SGSIII
Reactions: sicario666
Sent from my SGSIII
I'm feeling a little on the lazy side to do that right now. I know imei loss is a hit or miss. I'll just tackle it tomorrow. Thanks for the pointers NJAP
To fix the glitch...select menu soft key, select system settings, under system select developer options, select/check disable HW overlays...all better!
Awesome bro thanks for posting this, going to add to OP!
I have tried every ROM and IMO the smoothest, most stable available is d2vzw-CM10-invisiblek-KANG-08-16-2012-1820.zip found here Goo.im Downloads - Browsing cm10.unofficial.nightlies I have tried the nightlies and had problems with them. I keep doing a complete wipe and going back to KANG 8-16 which to this day I haven't had a single issue with.
Yea there are a couple Kangs of CM10. My personal favorite Kang is JellyBro. They are usually pretty good, on my N7 JellyBro is the best.
Updated OP to reflect new nightly... 8/22
I might try that ROM, so far CM10 is great but for some reason my gmail and google voice arent pushing. I have to go in and refresh to see new messages in both.
Is the 4g icon supposed to be grey on this? the data is working but it is blue on my other ICS devices
NotJustAPhone is right, it is suppose to be blue.
My signal icon is blue with both 3G and LTE. Grey means you're connected to the network. Blue means you're also connected to Google's servers.
Sent from my SGSIII
Interesting thanks! not being connected to google services would explain why my emails and google voice need to be refreshed manually.
Anyone know the fix?
I tried reflashing GAPPS but still grey
Sounds stupid but did you try toggling airplane on/off?
I assume that you've tried rebooting the phone to restore the link.
Try deleting app data and app cache for Gmail and Google Voice. If that doesn't work, try reflashing the ROM after wiping cache and Dalvik. You'll need to flash Gapps after flashing the ROM.
Sent from my SGSIII
Fixed it
I wiped cache partition as well as davlik and reinstalled GAPPS and now all is well
DIdnt need to reflash the ROM or wipe data thankfully
Update
**Spoke too soon back to grey guess i will try reflashing the rom and GAPPS**
8/22 is running perfectly. Besides the NFC, seems like everything else is great.
Cool...maybe you can chime back in when you get a little more time on 8/22 and give us an update...thx for sharing! I'm hesitant to leave 8/16 KANG...
Just flashed and set everything up. Ahhhh good ol AOSP. I missed you. All seems fine and dandy. Cupcakes and rainbows here. 8-22 nightly. Screen flicker yeah. Not a deal breaker.
FissionMailed via CM10 GalaxyS3
The fix for the screen flickering has been updated on the OP, potential fix for it.
startrek1966
