[ROM] [PORT] SIII for the Optimus V CM7.2 | UPDATE 09-19-12 FULLY THEMED
I was gonna see them at warped tour but I went out of town. I might see them on the 17 with Pierce the veil but they sold out so ima need to buy my ticket from someone who already has them
I was gonna go but they sold out as soon as I went to by the tickets I love Pierce the veil though
I
got the update for s3 from the Holocaust launcher pretty sick looking if you ask me ;)
s3 for the optimus V :D
Mmkay. I tried it, and honestly I liekz it. This one is very battery-efficient than any other of the CM7 roms I've tried. The launcher, it looks identical, but I'm sticking with the XPERIA S launcher. Everything is works as mentioned. Too bad I can't use 3G, as the damn thing is borked. -.-t Anyways, good job on the rom port!
Let me try and see if I can fix the 3G. All I have to do is edit the framework.jar.
I'll compare this ones framework.jar's cdma folder to,say, MiRaGe's. I'll look at the CdmaSMSDispatcher.smali mostly. If I notice a difference, I'll edit that file.
EDIT:
Try this one: https://app.box.com/s/2dm9h350y8pegd1jerl1
md5sum is in the comment
I changed the CdmaSMSDispatcher.smali from the framework.jar and the apns.xml file from the framework-res.apk.
I made sure the ROM booted up, changed the CPU to 768-480, looked around some. Everything looked good. No fc's. I currently do not have service (broke, so home phone is it), so you wil have to see if this helps. If not then it's you location to the tower, or their working on it.
Hope this will work to fix your 3G blues.
AndyOpie150
EDIT:
AndyOpie150
Okay, AndyOpie150, I got it. And it works now. 3G is fully operational, so no more constantly switching ROMs. Although in Houston, around my campus (YES Prep Southeast) I get signal drops. (Not major signal drops, [Signal drops like no data and just voice don't happen at all.] just like 1x Data & Voice. But, it's not like I NEED my data. Thanks, AndyOpie150!
I have a 3G fix for better connections. I also have a GPS fix for faster GPS lock.
Sent from my LG-VM670 using AC Forums mobile app
Huh? Oh no, I'm fine with the signal drops around campus. They gave me the password for the 802.11X WiFi, so I have data, and I use Google Voice. Thanks again, AndyOpie150!
I too do not have 3G, so I tried downloading your ROM but Box reports you are out of bandwidth. Any way I can pull this from you?
Thanks.
I will be moving everything over to Mediafire in a couple of days. Will change link and give you a PM when done.
Wish they had this for the HTC one
Sent from my HTCONE using AC Forums mobile app
I'm sure you can throw stuff together.
Using CM, you have a CM10.2 them on the market that works for ICS, and JB by Thomas.
You also have all the Samsung apps mostly ported now. You can get SUPER close to this with ease. :rolleyes:
Sent from my HTC One V using Tapatalk 2
Thanks for the encouragement :)
Sent from speedy ecliptic one
r3dpuk3
