[ROM] [PORT] SIII for the Optimus V CM7.2 | UPDATE 09-19-12 FULLY THEMED
Re: [ROM] [PORT] SIII for the Optimus V CM7.2
When flashed the rom the boot animation and homescreen was awsome but the dialer , contacts ,and setttings is still gb stock. Anyway to fix this?
You have to download the MDPai version. Ill paate the link to it.
No, this rom has Theme Manager deleted because it replicates the S lll. So you will need to install the theme manager.
Go to OM Mandylion thread and get the Theme Chooser zip from his links. He made a flashable zip.
I'm sorry guys for the Theme Issues. I'll include theme manager in the next update and I'll incorporate the theme. This was the initial release, so of course there's bugs, considering it's also my first post.
Ither use Widget Locker, Go Locker, MIlocker, Different Rom, Or an HTC phone :P
For theme issues, Re-apply the Touchwiz theme by installing Theme Chooser from a CM7 rom.
Thanks for the excellent ROM PORT. Install without a glitch. It runs smoothly and I like it. One thing I cannot make it to work, wifi hotspot, it stucked at authentication.. or Obtaining ip addresses.... Will continue to try...
bun
bun
Whaaatt? No. Please tell me you're kidding. Can anyone confirm this?
Sorry to say, I am not kidding, hotspot wont work, just tried for another hour, with 3rd party app, same same, stuck at authenication/Obtaining ip addresses.... any suggestions where to look? And in about phone, it showed as 4.0.4, nice trick. Who care? This is the best ROM i have tried so far, stable, smooth, flashy and
bun
Field trip. Took my brand new shiny OV with SIII ROM for field trip. OMG, GPS lock is... fast is a understatement, it is instant. I used to wait for 3 - 5 min for it to log, sitting in a parking lot and wait, this time, I got in the car, started the car, and turned on the OV, it logged instantly. Thank you ilikechicken123!
bun
bun
You just sold me on this! Downloading now
Hey, that was not a one time incident. I went home from work, and the GPS logged right after I set destination. Good job.
bun
Thank you so much for the positive feedback! I'll try to update this tomorrow, I'll be porting it from scratch, Roaming Indicator will be 'turned on', Hopefully it'll be fully themed, I'll see if that fixes portable wifi (Which is working for me, bad download?), and possibly a few tweaks added. We'll see what happens.
EDIT: tethering ISNT working.
Maybe include Theme Chooser into Data/App and see if reapplying changes it. :)
Update is uploading. Everything works. EXCEPT wifi tethering. I confirm it. I suggest using barnacle wifi tether. I'm not positive it'll work but if you disable the WEP check thing, it might be possibly working.
Toxxyroxy
