bonanzabucks
- Sep 18, 2010
- 159
- 1
- 0
Re: [ROM] RandomROM 2.2 vers.4 [Journaled] EC05 :: (Updated 6/23)
Not sure of the numbers, but I’m using CWM 3.something that is NOT the purple one. I know it’s not the latest version and I’m not sure what difference it would make aside from aesthetics. I could be wrong, though. I’ve also tried wiping everything you mentioned (delve, cache, factory reset…whatever they’re called) at least three times before installing the ROM.
And I’ve had no trouble installing other ROMs and they work fine for everything. I’m currently using Baked Snack 2.4, which I downloaded solely because it was supposed to have the best battery life of them all. The Baked Snack ROMs were good up until 1.6 (the latest Android 2.1 version) and after that, I don’t see a huge improvement. If anything, I think the battery life has gotten noticeably worse. Before, it would drain maybe 1% an hour when it was idle and now it’s definitely way above that. I also notice that the cell signal has been pretty bad in some places, like my office, where it used to be pretty reliable. Anywhere that I used to have a solid two bars, it keeps bouncing between one bar to roaming, always searching for a signal. I have to use Roam Control to keep it on roaming mode so I can get some sort of signal at my office. Now the signal problem could be a Sprint issue (maybe because of them losing their roaming agreements or upgrading their network) and could very well be coincidental, but the signal definitely gotten worse after I upgraded to Froyo.
