[ROM] Reborn ROM v2.1 5/13/11
Coming soon. Very flexible as well. It was adopted from this thread: [PORT][MOD][Deprecated] Notification Menu Power Control Widgets for Sense based ROMs - xda-developers
All of these toggles are available:
toggleAirplane
toggleAutoRotate
toggleBluetooth
toggleBrightness
toggleFlashlight
toggleGPS
toggleLockScreen
toggleMobileData
toggleScreenTimeout
toggleSleepMode
toggleSound
toggleSync
toggleWifi
@vee Is this the link to changing the widgets that you talked about? :-$
navigate to /system/customize/widget.txt and adb pull it then edit it to which buttons you want then adb push it back to your phone then reboot and enjoy
Reactions: anon283326
Thanks guys for the help with the status bar widgets! I finally got it to work, I'll post a screenshot of m device later...(P.S: Use "Screen Shot It" from the android market (or just download the .apk here, a this link) to take screenshots on your device. Has worked great for me,you can even activate it by long-pressing the search button if u want):
Btw, @arhtard, thanks again for telling me about the recovery problem with data2ext4. I switched back to this ROM since i missed it so much, and i had a big problem enabling data2ext until I installed the modified data2ext zip found on this site here. But changing recoveries was a good idea, the recovery you posted is a hell of a lot better than my old ThunderC stock custom recovery :)
Reactions: arhtard
I agree 100% :) I've learned much of my android knowledge from these forums myself. Thank you so much for the extra mods. I, too, have selected a theme based upon black & white, and these fit it perfectly. I'll have to remind myself to thank you on this forum later, since tapatalk lacks the feature on android :p
Peace! (/|\)
Sent from my LG Optimus V Using Tapatalk
i continue to keep coming back to this ROM. after being led to the data 2 sd mod, it's such a smooth running ROM. the only downside is the TWC fix, but it's not that hard to toggle airplane mode for 20 seconds after reboot.
really liking the themes too. i really enjoy the transparent themes.
Reactions: mjs2011
that's right! thanks!
still miss CM7 goodies a little bit, but this ROM just runs so smooth.
Here's a higher resolution one, sorry :p
Is this rom still being actively maintained?
Yes, i believe so :) Earlier in this forum, the developer posted that he was going to update it one more time before trying to take on a Gingerbread base for yet another great ROM...so that would make the new version he's planning on making Froyo-based as 2.2 or something like that. But, like my good friend arhtard said, this ROM is great as is right out of the box, just add a theme and a few tweaks and you're set :D
There aren't any major bugs besides trying to attach a sound file in MMS, sadly :-\ but hopefully that's what he's going to fix in his next update...
Are there any apks or some sort of quick fixes for this? I REALLY love this ROM, but i send my friends ringtones all the time from my phone, and this feature is a must. So far i haven't been able to utilize it with this ROM :-\
There aren't any major bugs besides trying to attach a sound file in MMS...
hey
after reading this i tried to send a sound file, it failed
so i decided to mess around, i installed ath3nos cm7, tried to send sound file, same results
i was kinda confused, so i installed drews cm7, tried to send a sound file, ending with same results
not sure whats going on, haven't tried any other roms yet, if my day stays pretty shot, i may end up trying more. i know its no help, just thought i'd throw this out there
the kitchen has been broken for a few days now =(
i guess the dev is out on a boat in the ocean and cant fix it right now
check out these battery icons he's said to add soon
late
well there was a difference, reborn force closes
the cm7's just hang at sending and never send, i dunno
kinda sucks though, i agree
hey
Thanks, man, maybe we can somehow figure out what the deal is with these ROMs lately ;) The ONLY two ROMs that don't have this problem are the original DEODEXED stock version, and the 20110601-signed build of CM7 for the OV. I've tried both, the stock one is too...well, stock, for my taste :p and the CM7 has too many unfixed bugs for me to put up with it anymore...
I tried extracting the "Mms.apk" from both of these ROMs, but the CM7 one is incompatible with Froyo ROMs and the other one is pretty much the same. There must be another system file somewhere that denotes whether MMS works properly or not :-\
I have no idea as to what it is though, i'll have to research it some more.
Look at Harmonia, I send ring tones via mms to friends all the time. Never had a problem.
Well, it may work in the specific ROM, but if I were to extract the Mms.apk from the /system/app directory, it wouldn't fix my problem, since Harmonia is also mainly Froyo-based :-\ it's a system file in this ROM thats buggy, sadly...but could u post a link to that ROM? (don't forget to credit it's developer) maybe I could try it :)
It didn't work :(
Yeah, it's definitely got to be another file somewhere...
araelbenjie
