ARCHIVED: [ROM] Reborn ROM v2.2.4 - 7/24/11
Status
Not open for further replies.
What do you want it to be? It could be "Cooked" to your liking in a theme... or a STOCK theme with JUST the dock image changed. Unless Nick7 wants to change it in his ROM for future versions. :)
Well I'm currently using LPP and I subbed the icons for custom icons on the dock and I love them. They fit perfectly with my softTouch theme (Thanks!!) and my Beautiful Widgets pink clock. (have you vomited from the pure sticky sweetness that is my phone yet??) but when I am using the stock launcher, have whatever icons are in the app drawer. On LPP, you can long press and select "Change icon" and just change the icon without changing the entire shortcut or action.
Ok i get what your saying... ok..
What you need to do is go to your app drawer. Press and hold on the app you want to put in your dock. Then slide it over the icon on the dock that you want to replace.
You do this just like adding it to your screen as a shortcut.
Sorry I didnt understand what you meant before.
She means, can you change the icon that represents the app. Example, make the gmail app have a different icon but still be gmail.
And the answer is........... no, sorry not with the stock dock.
Sent by Tapatalk ----- Optimus s
Reactions: Jessicalt1
LMAO! ok.. I am gonna go to my corner now. I obviously cant comprehend anything today. Im having a re-re moment. :)
I ended back at stock rooted VD.. I don't know what it is with my phone, but reborn gave me all sorts of issues, black screen, freezing up. Tried Clean and dirty installs none helped.
Have you tried Re-Downloading the zip for Reborn Rom? Very unlikely but maybe it had errors downloading..... Sorry man. Reborn is the best ROM out ATM, IMO.
Sadly I did. I really enjoyed it too when it worked, great battery life and zippy performance.. Maybe I'll give a try again someday.
Not sure what to suggest... know that my phone runs pretty well on reborn... and it's been running reborn for a while now... :)
Has anyone had the problem of the icon showing that the Optimus is still plugged in and charging when in reality it is not. This happens OCCASIONALLY after charging my Optimus S immediately after unplugging it. A restart fixes the problem. I was just curious if this has happened to anyone else.
I am running Reborn ROM v2.1 with the reTouched theme.
Never had that issue before. Odd tho
I haven't had anything like that happen.
I have the opposite happen occasionally, where I am plugged in, but the USB and charging icon does not change. I have to go unmount and remount the SD card and everything is fine...
This afternoon, I took pocket dialing to a whole new level - Pocket Purchasing. I pulled the phone out of my pocket to discover the Amazon Appstore was downloading a bunch of apps. To my horror, I see one was an app that I had not purchased. Sure enough, soon afterwards I got a receipt from Amazon confirming my purchase. I have contacted Amazon and hopefully they will refund my money.
Nick, if you'd have time to look into the issue where the unlock widget makes the keys wake the phone again, I'd be happy to send my refunded amount your way. :)
Did you flash the Stock Button Layout zip?
I'm running unmodified Reborn ROM. When the phone is locked, the buttons won't wake the phone. Whenever I unlock the phone using NoLock or the PowerControl Widget, the buttons wake the phone again.
Basically here's what happens. I tested this using both the NoLock widget and PowerControl. When the widget is set to keep the phone locked, the buttons will not wake the phone, but when the widget is pushed to unlock the phone, the buttons wake again. :confused:
Is there a reason your not just using the default lock instead of widgets?
BTW, Sorry to hear about the purchases! That sucks!
Is there a reason your not just using the default lock instead of widgets? !
I like to have my Phone locked for security when I go out, but when home it is a real pain to put in the password all the time. The widgets are a lot easier than switching the lock on and off using the setup menus.
Is there a better way?
Status
nettirb
