ARCHIVED: [ROM] Reborn ROM v2.2.4 - 7/24/11
Status
Not open for further replies.
Goes to call log. well puppy poo. then I guess switching back to voice wont be possible on Nameless. :(
Here.
And just a little note. Everyone wants some sort of tweak, modification, or patch to make the ROM "perfect." We cannot keep up with all the requests. The ROM is as is, if you want something edited or modified, give a shot at trying it yourself. I think you guys will actually enjoy the learning experience.
Thanks for understanding.
Great idea! Where would I start to learn this stuff?:confused:
How do I un install some of the Sprint apps?
Use the file manager in the ROM. Enable root manager under file explorer settings, mount RW in menu, and navigate to /system/app and delete what you don't want.
And if you find this a bit scary, install Titanium Backup, (Free version works just fine). Open it up, go to the apps list, scroll to the thing you don't want, (I hate sprint zone, for example), and click it. Click "Uninstall".
great job . really liking this rom.thanks alot. there have only been 2 issues for me so far the gps doesnt seem to fully work and tapatalk isnt really working it say "pad block corrupted" whem try to browse for a forum
Explain more about how the GPS isn't fully working. What doesn't work? Which apps? etc.
As for tapatalk, uninstall and reinstall?
uh oh can someone confirm the gps problem? i'm gonna flash tonight but am going out of town tomorrow morning!
I am having the same issue with tapatalk as well. Did some google searching and found this
pad block corrupted???
It says you can't find it in the market either and sure enough... searched the market myself and no luck. Not sure what is going on.
for gps it works on googlemaps but not weather forcast and clock wideget(so i just put in my zip no biggie)
for tapatalk i did try to uninstail reinstail but didnt work it works fine in zephs cm7
Just flashed this after clearing everything from ThundeRom and running smooth. I'm currently having an issue getting the calendar to work though. When I try to add an event is says I have no calendars. Any ideas?
yes, tapatalk is experiencing issues right now. You'll notice it no longer shows up in the android market at all.
Not ROM related.
Status
affansahab2021
