[ROM][Repost][06/05/11] Comm ROM 2.1 (UKB) from TSM **Updated 06/20/11**
Re: [ROM][Repost][06/05/11] Comm ROM 2.1 (UKB) from TSM **Updated
Ahh... I knew it was somewhere. Thanks. That helps a TON.
I'm having a weird issue when deleting SMS threads. I highlight the message and get the Delete threads popup, it then deletes the messages but leaves a blank message with the contact in the main SMS list. Have not seen this before in any other Roms. On UKB 2.1 with Comavolt. No theme.
How long should it take to reboot after loading ukb 2.0? I loaded the non kernel file through CWM all 3_30 and then without rebooting I loaded the ukb 2.1 patch then rebooted. It was stuck on the android screen in a loop for over 30 minutes. I had to pull the battery and boot into CWM and restore the NAND backup I made before I started the process. Should it take longer then 30 minutes to boot and am I just impatient and I should have waited longer? Has this happened to anyone before? I?m not sure if it was because I used CWM all 3_30 which is CWM 2.5 and I should have used CWM 3.0. The OP says to use CWM 3.0 but 2.5 did work for testers. Any help or advice would be greatly appreciated. I am currently running superclean 2.9.2 with comavolt non voodoo kernel and EC09 modem.
I let it boot completely into UKB 2.0 then went back into recovery and installed the 2.1 patch. Did not have any problems. Used CWM 3.0.
Do you recall how long it took to boot after installing UKB 2.0?
Just a few minutes, just like any new rom. Obvious but make sure you clear cache, dalvik cache and wipe data for this rom.
im in recovery, 2.5, and im up to installing .zip file. it says finding update pakage, opening update package, then installing update. my question is how long does it stay at installing? im up to 5 min and nothing has happened yet. did i do something wrong?
Anyone know how to get crackle to work on ukb 2.0?...
I finally leapt from SC 2.9.2, does this 2.1 ukb have a dummy tether?
I tethered a little while using CR 2.1 and didn't see any increase on my bill. Either CR has the dummy tether, or I used up such a small amount of data when I did tether that they weren't going to bother with me.
Reactions: akabaka4
r3dpuk3
