Seems like the black notification bar makes notification text invisible (because text is black too)
I like everything else though, just looks like the text should be white or gray...
I'm aware, I made it
I have gone through all the Optimus V roms--RedRevolution, Rodimus, aospCMod CM7, and Zefie's CM7. The 2.3 Gingerbread roms yielded poor battery life. So now I'm back on Rodimus since it got updated.
The top things I miss about the GB builds are the notification bar power controls, the GB keyboard, the electron beam screen on/off animations, ability to charge quickly. Battery life was the final judgment in jumping back to a Froyo rom.
Hey, mmmark111 or anyone else. Are you able to integrate the notification bar power controls? What about the electron beam animations? If you could somehow integrate those into this or any 2.2 roms that would be great.
Screen off CRT effect won't happen and the power controls would take more time than I have.
Is it me or is it in the mod when i try to charge the phone by plugging it right into the wall the phone will not charge. but if i plug it in usb it charges fine. im using the rom with theme 2 i have tried couple different chargers to
It's not the ROM. So it must be your phone? maybe?
I have a few observations to report since I would not go as far to call them issues yet.
1) Sometimes, I will lose my shortcuts on the bottom of the screen. Instead of phone, contacts, web,... they will be replaced by "+".
2) I download V1.2.2 RodimusROM but phone information says v.1.2.1. Did I do something wrong here?
That's LauncherPro
Version number is incorrect. You're on v1.2.2.
