ARCHIVED: [ROM] RodimusROM v1.2.3 + xionia [4/3/11] All themes update
Status
Not open for further replies.
No comment on the status bar thing? I would really like to get rid of the clock and battery icon for the status bar.
Sent from my VM670 using Tapatalk
Google Latitude doesn't auto update position in backround with this ROM, unless you will open maps on foreground.
maybe setcpu issue?
or is something turned off in ROM?
He's already stated he is in school and was taking a few days off, we have to be patient. Just relax.
Do any of these roms address the 3G standby battery drain issue? While running this rom, I noticed a crazy spike in battery use under 3G. I followed the directions found here: http://forum.androidcentral.com/optimus-v/57943-excessive-battery-drain-even-standby.html#post579387
And my phone is all better, at least until I reboot again. I don't fully understand the problem, but is there any way to put in place a permanent fix?
After reboot Time without a signal" is 50%.
Than I turn Airplane mode ON and OFF.
And time without signal is slowly going down.
But a had problem with every ROM with Optimus V yet and lot of other phones reporting it.
you can fix it with *#*#4636#*#* and select "CDMA only" and then select "CDMA auto (PRL),
but simple airplane on/off work as well and you have to push less buttons :)
It will be nice is somebody can write some script like and put it in ROM:
start
1 min after boot check if Time without a signal" is 50%
if no = end app
if yes = turn Airplane mode ON and OFF
1 min after app start check if Time without a signal" is 50%
if less = end app
end
start
if no = end app
if less = end app
end
Just install this.
Reactions: mmarz
Jmel, I wasn't really being insistent or anything. I merely asked a question earlier that he had plenty of time to respond to, yet he ignored it and responded to other questions. So I'm simply re asking the same question. I could have trolled, but I am aware that he has schooling. Plus I do enjoy his work, wouldn't want him to stop now.
Is anybody else getting an issue where the Google Voice Search app is force closing immediately when it opens?
I had the same problem Rae.. I guess it's not included in the ROM, but no big deal. Just install it for free from the market! :)
BTW this ROM is awesome! Great work, I like it so much more than stock + xiona.. super slick looking and I get awesome battery life, too!
I found 1 problem with 3/6/2011 ROM. I was not able to detect location using wireless in google maps. (GPS Location works fine) Is anyone having the same issue?
Has anyone been able to install a diffrent version of launcher pro.? I've npticed it always fails and I would really love to use a diffrent version along with the newest one
I've installed ADW launcher ex, more option choices and themes, in my opinion. Then I uninstalled launcher pro. Everything has been working fine for me thus far.
1. Install and set a different launcher as default otherwise you'll be reflashing the ROM since you won't have a launcher
2. Uninstall LP (I used Ti)
3. Install different version of LP
4. Switch LP to default launcher
You have to first install a different launcher. Then use the native app manager (not titanium backup) to uninstall launcher pro. Then, install your version of launcher pro. And finally, you can remove the launcher you installed to begin with. If you forget to install a different launcher first, you'll be locked out of android when you uninstall launcher pro.
Status
Dugoh1
