I thought you changed it to 10Because it's kernel 005....
Space-wise the Stock + Xionia ROM is better. Once I install all the apps I need, I have about 60mb left on Stock + Xionia vs about 35mb on Rodimus. In terms of battery use, I didn't see much difference (compared to CM7-based ROMs these two are much better when it comes to battery use).Anyone know how the battery life is compared to the Stock + Xionia ROM? I'm on that now but ready to try something new. My main concerns are battery life, and how much space is included in a ROM (as right now I only have like, 12mb left)
Didn't mean to come off as anything bad, I just really wanted to know. That being said, thank you very very very very very much for the zip to get rid of the clock. In case I want to revert to full stock for any weird reason, is that reversible? Doubt I will need to, but it's still nice to know.
I've successfully rooted this WITHOUT recovery.
I have no idea what to do after the root to install this rom. Any help?
Free space with a clean install of stock is 142mb. Free space with a clean install of RodimudROM is
135mb. The difference is caused by stock not having a bootanimation. If a few mb is a dealbreaker, just delete the bootanimation.
I paired immediately. but it's not letting me anymore. I used titanium back up but I told it to ignore the BT settings.Worked great! Thanks for your efforts!
Edit: worked with pairing on pc, but failed in car...
Car has 4 digit code, pc was 6 I think...
Also worth noting... after I flash, I then download restore my titanium backup which was restoring my bluetooth profiles.
Drezliok, did you pair immediately after flashing or did you restore from a backup as well the first and second time?
It paired with my PC fine before the black and white them is applied. Aftwards it's a no go. I will redownload the theme pack from one of the other sources and see if I just got a bad zip file.
I've grabbed the OG theme and I'm going to test in a few minutes with my car.
I think it will work. I paired with my PC then installed the theme, it broke the bluetooth.
Yep it worked.
So the blue and black theme has issue with bluetooth, how ironic
Another thing I noticed, is that with the updated themes, scrolling through homescreens with a live wallpaper is very very choppy at first, until the cpu scales up...
Can you try changing to the grass wallpaper and see what your results are?
