I am using a dual head unit. I don't remember the model number, but it allows you to make/receive calls and listen to bluetooth enabled devices, such as a phone.
Like I said, I have pinpointed the issue though, so I feel better now. It is definitely the newest v2 black and blue theme.
Please dont cross post problems to threads that arent related.Yes, I try posting in the appropriate threads but they're dead compared to this one, so if you can please allow me to post my problems so others can reply quicker to get this rom installed on my phone quicker :-D.
well, I tried putting Xionia recovery on my phone and now when I go into recovery a blue screen with white letters appears saying:
I tried getting the Xionia recovery, and when I go into recovery now it turns into a blue screen with white letters saying:
Fastboot
edc_start()
Aawwww balls. I thought I had it, haha. You guys will have to wait a few more days. In the meantime, try switching out the settings.apk in the black and blue theme with the stock one and try again. Also, use the build.prop from the ROM and not the one from any of the themes. Oops
Thanks for being patient![]()
So bluetooth and location services only work on blue theme v1?
How come after i flash the recovery and it does the auto reboot my phone is getting stuck at the LG screen and not going in to recovery mode?
OK, I flashed the new release of the rom and the B&B theme v2, and successfully paired my phone. I had some issues when I restored from TiBackup, and also when I tried pushing the ROM's Settings.apk to my phone, so I reflashed everything and started over. Here's the steps I took that worked for me:
- Make a backup
- Flash the ROM
- Reboot (not into Recovery)
- Reboot into Recovery
- Flash the Black & Blue Theme v2
- Flash a2sd
- Run "adb shell" on computer to reinstall a2sd (it will reboot the phone)
- Go out to the garage and pair my car to the phone
- Do a happy dance
And since then, I restored my app (and some system) data from TiBackup, and just went back out and verified that my phone and car are still paired up. Oddly, I did have to go into Bluetooth Settings and tell it to connect, even though I had enabled BT from the Power Widget. So there may be an issue there.
Otherwise, the only issue I've found so far on the new ROM is that Google Talk fails to authenticate with my account (it's an apps account, if it makes any difference, and yes Talk is enabled for my domain.) I don't use GTalk though, so I don't really care.
