[ROM] rubiX Focused 0.5
Question im running the ruby .5 and I keep getting text messages twice. Its the exact same message only twice. Any suggestions?
I'm running flyX and I get the same thing once in a while. It may not be a rubiX problem
the ROM installed a new text client . So you will get dupes of the same text because one is on stock text messenger , and one is from ROM. IF you have titanium backup find the one you dont want to use (i am using the stock) and freeze it . The other one you will leave alone . There is another way to stop the dupes , but it involves changing the names , and im not experienced enough to walk you through that . But the titanium way works like a charm
I Deleted what i thought to be that test messanger that was in the rom, and i also deleted the launchers because i prefer launcher pro. Im still getting the dupes.
Do you have titanium backup?
I just downloaded it now and froze all but handcent. The problem seems to be ok now.
droidfootball
