[ROM-STOCK] iKReaM.605.19.ROM.v1.0.RLS-R3Ds
the only other issue I had was that the market wasn't updating itself, so I had to uninstall it and find the play store app from another rom and install that instead.
Can you tell me where I can find the Play app? I still have the old market with this ROM and I have tried to get it to update with no luck.
I can't share any picture from the gallery on anything....Facebook, mms, email...... R3D please fix!!
Sent from my ADR6400L using Tapatalk 2
Nice clean ROM.. ?everything works? fyi.. some reason my market (google play) won't process purchases... try to buy an app & it gives me some unknown error.. other than that pretty smooth..
great battery life (extended batt)
(Full size: https://t.co/QgnsDQkY)
Android AdvicesDownload Latest Google PLAY Store 3.5.19 APK for your Android
rename this apk to "com.android.vending.apk" and copy it to the /system/app folder and overwrite the current one. reboot your phone. make sure the permissions are correct, (rw-r--r--) and then install the apk. if you get force closes, clear the cache and data for the app.
*sigh* great battery life is considered to be 9+ hours... I almost miss my Blackberry. now I need to carry chargers with me everywhere!
I also had very bad service so it kinda killed it, yesterday I got about 11.
When using stock gallery, app force closes when trying to share a picture via Facebook. Fix permissions doesn't solve the issue.
The alternate gallery works though..
Reactions: trter10-imore
Anybody notice Task Manager in quick settings won't let you selectively shut down individual apps... ?Refresh & Kill All is the only coponent working?:-$
Have you tried sending a moms from gallery? It force closes then too and I'm looking for a fix. If you go to the ics themed gallery and select a picture to share you won't even see the messaging option from the drop down menu.
So I just flashed this ROM the other day and thoroughly enjoy it so far. My only issue is that my bluetooth has no audio. It will connect and pair just fine, but there is no audio to the earpiece. People I call can hear me, but I can't hear them. I've checked to see if it's something with my headset but I'm out of options (I use the Plantronics Discovery 925). Does anyone have any suggestions?
Has anyone ran Liquid 3.2 prior to installing this? I was just wondering if there was noticeable difference between the two with respect to GPS, battery life, and overall performance?
(I'm just contemplating switching to a new rom)
ruatahmar
