[ROM][Team-Coterie] GingerBread V
I would like to mention before anyone bricks their phone stupidly, that the factory reset option is available in settings>>privacy>>factory reset.
If you value your time and your OV, do not use this option as it will brick your phone.
I expect most of you know that already, but I expect there may be a few noobs hiding in the shadows so I wanted to point that out right away.;)
Well this is a surprise indeed. Anyone try flashing iScream Kernel on this? I might take a whack at this later.
just wondering if anyone else had the mic issue when trying to make/receive calls.
Downloading and flashing!! I couldn't find a md5 of this Rom? But my download are always good!! I hope;)
Good job ill check it out when jerry gets the chance to post the rooting steps for the vm update since I used my phone for testing and can't re-root it yet lol
Sent from my VM670 using Tapatalk 2 Beta-4
Awesome build!!! Thanks!! Look like gingerbread!!! All is smooth found one bug tho. When I go to setting,sound it force closes, is this a bug or a bad flash! Thanks
In the OP it says its for ICS and GB built from LG source.
iscream kernel works but there are a few issues. first is that it will flip flop your menu/home keys. this can be fixed by editing your keylayout files in /system/usr/keylayout the ones you need to switch are 139 and 102 in files thunder_keypad.kl and qwerty.kl. i tried button remapper but it wouldnt let me do it. there also seems to be a problem with it waking up after screen off you can get no frills cpu overclocker and raise your min to at least 480. i use min 600 max 806 with interactivex goverener but every phone is different. that should minimize the problem. if it does still happen i just hit the power button a few times and it wakes up. The camera preview only shows a white screen. there is a fix provided by thekraven here. so all in all yes it does work but you've got some work to do to make it very useable. as a side note..... it does feel really fast. much better then when i tried it on backside iho CM7. if you feel like trying it just make sure to do a backup first so you have an easy way back.
by the way... i see ICS screen rotation animations... leftover from useing IHO files to get this running?
GingerBread from Google's source is Kernel-less, I'm cooking a GingerBread Kernel as we speak, because there is no STOCK GB Kernel... because this is the First Ever Stock, Real GingerBread ROM for the Optimus V. This IS the closest thing to a STOCK GingerBread that we have for the Optimus V, It's this or Harmonia which is IHO Stripped down the the bare, yet It is still IHO, a lot more custom then stock.
Just a little semantics here, this is not "stock", this is AOSP. ;)
Stock implies a Gingerbread release for the phone itself. You have gone beyond that and created the only port of AOSP I know of for the Optimus V, be it Froyo, Gingerbread, or ICS! Good Job!
note- stock froyo is very close to AOSP, but it has VM's bloatware. ;)
We had AOSP a while back, it was in fact the first GB we had I think. However, it never ran right being a port of a port.
Idk where the dev went.... he hasn't posted for days
kitlis
