[ROM][TN]MIJJz BLEND ICS[OS 4.0.4][FE10deodex/odexed]THE GOODNESS
Re: [ROM][TN]MIJJz BLEND ICS[FC22/24][OS 4.0.3]"THE GOODNESS"[v3.
I was gonna update the first post to include v3.2 but it lookls like the dev is gonna update the ROM to FD02 tonight so I'll just wait for that :)
EDIT: Apparently I already updated the OP to version 3.2 :p
Re: [ROM][TN]MIJJz BLEND ICS[FD02][OS 4.0.3]"THE GOODNESS"[v4.0]
Updated OP to include latest build.
How many users use this rom here that dont go to XDA or Team-Nocturnal.com??
5.1 is out now. Even better. I'm loving this rom... I installed beats audio on it also and the sound is superb.
Just flashed it last night and it is the best ROM I've tried so far :)
If I want to reflash this rom, can I just do a flash over current version (v5.1) or do I need to go back to gingerbread and start over?
In the instructions it says to format just from prior to 4.0 or first time flashers so you should be fine.
Sent from my SPH-D710 using Tapatalk
Reactions: skyo12
Right, no need to go back to GB. I install new versions over the one I'm using without any issues. Just be sure to wipe accordingly :)
Re: [ROM][TN]MIJJz BLEND ICS[FD02/05][OS 4.0.3]"THE GOODNESS"[v5.
Updated the first post :)
Reactions: skyo12
Thanks guys!
This is a beautiful ROM and it's nearly flawless. Still letting the rom set in to gauge the battery life but otherwise it's been perfect.
Quick question for people who are using the current version. How do you get the email/Messaging icons to display the number of unread emails and texts?
Thanks guys!
I didn't see an option for that in the default programs. You might need a third party app for that.
Reactions: skyo12
Re: [ROM][TN]MIJJz BLEND ICS[FD16][OS 4.0.3]"THE GOODNESS"[v6.0]
Updated the OP to v6.0 :)
Just a warning to anyone that is going to flash this update; v6.0 comes with stock FD16 NO CWN kernel. In order to get CWM back, you need to ODIN FD02.
It should also be noted that after 5.1 the hacked hotspot also no longer works
Edit:actually that should read the hotspot I'd no longer included in the build at the moment
Must say I absolutely loved "The Goodness" I did switch to new ROM on Tuesday...called BluKuban. once mijjz puts out 8.0, I'll switch back and compare.
Sent from my SPH-D710 using Tapatalk 2
Re: [ROM][TN] MIJJz BLEND ICS[OS 4.0.3][FD19]"THE GOODNESS"[v7.0/
I was thinking of trying out BluKuban but I can't seem to go away from Mijjz XPLOD MINI ROM :p
Never tried that one, BluKuban has a ROM UPDATER built in, he updates or themes any apps, he pushes it, and I click ROM UPDATER, if I want whatever it is, it loads, reboots to recovery and installs automatically, very bare minimum ROM to allow for total user customization, but I'm gonna flash Goodness 8.0 once it's out, really enjoy that ROM too. Brilliant devs, I'm gonna learn to do some myself too I believe:D
That's actually waht got me interested in the ROM initially. I keep meaning to flash it but I keep getting new text messages and my OCD doesn't allow me to flash a new ROM until EVERYTHING is backed up.......lol
It was a slow morning so I quickly backed up my data and immediately booted into recovery to backup my current ROM.
Restoring everything now :)
r3dpuk3
