[ROM][TN]MIJJz BLEND ICS[OS 4.0.4][FE10deodex/odexed]THE GOODNESS
Cool, just flashed the FD26 modem a few hours ago, seriously like 24 better and benchmarks and speed test scores wee higher for 24 vs 26 on my phone.
Sent from my SPH-D710 using Tapatalk 2
Re: [ROM][TN] MIJJz BLEND ICS [OS 4.0.3][FD26] "THE GOODNESS" [v8
First post updated to v8.0 :)
Not gonna lie, there have been so many ROMs coming out and I've been trying them all.....lol
Here's why Blu is my favorite...
That's Blu on 4g
now I'm gonna get Goodness and I'll post here, Goodness is an amazing ROM, and will keep it add back up always....MIJJz is simply put amazing, but when you get these results coupled with awesome battery life, that's where I pick my daily driver.
I'm going to run Goodness 8.1 for a couple days and see what happens cause expect an OTA update within next 10 days or so of FE07, and results will determine which ROM I stay with, now, a tablet UI on Goodness, and no question, that becomes daily driver, let's see what MIJJz had up his sleeve after vacation
Are you getting random reboots when on 4G?
I installed 8.0 2days ago. n ive had about 6 power cycles. It goes to tho "Android is updating" n resets. It happens randomly. 3g/4g
I installed 8.0 2days ago. n ive had about 6 power cycles. It goes to tho "Android is updating" n resets. It happens randomly. 3g/4g <br />
<br />
Did you do a fresh install?
I got the phone fresh out the box n applied the EL29 ROOT then put the rouge rom on. from there, to 8.0 i did a compete format and wipe before installing ics. Any ideas?
Hmm, I'm not sure if I've heard of your exact problem before, but you should check out the xda thread to see if you can find anything.
Hmm ill check it out. Is there anyway to wipe the root cache without completely wiping? Its not too often that it resets,i just think it'll progressively get worse. I read somewhere that the ICS itself has this error sometimes. Its been apparent on the galaxg II for at&t
First time Rooter!! Galaxy II Epic 4g Touch ;)
It might be a bad download because I installed v8.0 and wiped everyhting and I haven't had any reboot issues. Are you on 4G? If so, then these latest ICS leaks have issues with 4G causing our phones to reboot randomly.
Im pretty sure its the 4g. I did a hard reset wipe n started from scratch. Haven't touched 4g n its been perfect.
Re: [ROM][TN]MIJJz BLEND ICS[OS 4.0.4][FE10deodex/odexed]THE GOOD
Oh yeah, using 4G on any ICS ROM will cause random reboots.
Updated first post for new stuff :)
r3dpuk3
