[ROM] Ubuntdroid 4 Final-Optimus T
This is a great rom. I also installed the build deluxe. After setting everything my mflops was a 9.9 and I overclocked at 1200. Thats pretty impressive.
Sent from my LG-P509 using Tapatalk
hi i have a question in th prepare process it says must have drellisdee's amon-ra custom recovery installed,but u just rooted with phone and have the recovery-RA-GNM-OPT-T-test.img.zip,recoveryon my phone can i still flash this rom with the recovery i have on there now?thanks in advance
i have answered and tested it myself this will work if you use the how to root optimus without touching a computer glad i didnt brick my phone and took the risk thanks!
Firstly, I'm new to this.
Seconly, I just rooted using the technique posted here. Do I meet the pre-requisite for this ROM of: ?
Thirdly, your website doesn't seem to be working currently.
i just installed it on my phone with the same root guide u used worked great just make sure to flash deluxe build prop for better performance
Thanks for your time!
hi flashed my optimus t with this rom like a couple days ago and now my phone turns off on its on at night like every otherday,is that normal?or how can i fix this?thanks in advanced.by the way this is way better then megatron and for some reason when i tried megatron it never saw my network at 3g
You need to flash Franco or Fserves. I had that issue too untill I flashed Franco. no issues.
How the **** did you OC it twice the mhz?
andiox
