[ROM] [VM701] Mobster Rom v1.4 update: 5/28
Ps; the port of my ICS to this mobster rom doesn't work, that's another thing that needs to be fixed. Id do it for yous but I don't have nearly enough time now. First time I've been on here in ages since my release of my ICS theme for team hydros ROM for the vm701
Sent from my LG Optimus Slider running Gelato 11 28/ Gingerkernel7.1. Theme:ICS
Re: [ROM] [VM701] Mobster Rom v1.3 update: 3/10
seems as such.... hasnt posted since the last update...
I can wait for updates and releases for whatever rom, I'm preoccupied with this Sidekick 4G in the meantime :D
Sent from my SGH-T839 using Tapatalk
Its not an error... its diff frameworks. So either u need to redo it on this framework or someone else needs to. That's not a bug. Not how that works.
Also id recommend setting the cpu on at least 800/196 if not higher for the idle/screen off speed.
Sent from my LGL55C using Tapatalk
I get a boot loop on virgin screen when factory reset in cwm any help? (I can restore a backup fom cwm and the backup works fine but I want a clean slate
I said the "port"
Someone said they PORTED it to this ROM.
I'm simply telling them their work was not successful.
If you want to start from a clean slate you will first have to install the stock rom (found somewhere on this forum), then boot once into stock rom, then flash this rom over stock rom (after clearing cache and delvik).
Just felt like sharing this
Sent from my LG-VM701 running Mobster Rom via Tapatalk
Can someone give me a detailed installation instructions? i just wiped my phone and want to install this rom and use it. I am a noob so any detail helps
Now includes Mobster Tweaks v3
#Mobster Tweaks v3
#Bravia Engine Service
ro.service.swiqi.supported=true
persist.service.swiqi.enable=1
#Increase Performance
dalvik.vm.execution-mode=int:jit
dalvik.vm.heapsize=42m
debug.performance.tuning=1
video.accelerate.hw=1
#Improve Visual Quality
ro.media.enc.jpeg.quality=100
persist.sys.use_dithering=1
#debug.sf.hw=1
#Saves Battery
wifi.supplicant_scan_interval=180
#Faster Media Streaming
media.stagefright.enable-player=true
media.stagefright.enable-meta=true
media.stagefright.enable-scan=true
media.stagefright.enable-http=true
net.tcp.buffersize.default=4096,87380,256960,4096,16384,256960
net.tcp.buffersize.wifi=4096,87380,256960,4096,16384,256960
net.tcp.buffersize.umts=4096,87380,256960,4096,16384,256960
net.tcp.buffersize.gprs=4096,87380,256960,4096,16384,256960
net.tcp.buffersize.edge=4096,87380,256960,4096,16384,256960
#Data Tweaks
ro.ril.hsxpa=3
ro.ril.gprsclass=12
ro.ril.hep=1
ro.ril.enable.dtm=1
ro.ril.hsdpa.category=28
ro.ril.enable.a53=1
ro.ril.enable.3g.prefix=1
ro.ril.htcmaskw1.bitmask=4294967295
ro.ril.htcmaskw1=14449
ro.ril.hsupa.category=9
#Disable Bootanimation
debug.sf.nobootanimation=1
persist.sys.shutdown.mode=hibernate
Just thought I'd put out an update :)
Just so you know mobsterz... that jit build.prop tweak does nothing at all. You have to enable jit in the dalvikvm. Meaning you need to compile the dalvikvm to enable jit. That build.prop tweak does nothing on its own without the dalvikvm dependency.
The stock rom doesn't have a jit enabled dalvikvm. You're welcome to use the dalvikvm from arearomq... it will work on the slider. Just please don't infringe on my settings.apk nor my customized themes I implemented.
Even so there shouldn't be any side effects :p
Nah it just won't do anything. But if you grab the dalvikvm from arearomq and drop it in this rom you'll see a 2-3 hundred point boost in benchmarks.
Reactions: Mobstergunz
Christ you scared me less. I updated it (lazy me didn't backup) and rebooted. After the bootscreen there was a quick white flash down the screen then just a backlight on a black screen. It sat like that for ~25 seconds. I was scared less.
Then the screen came on and everything was like normal :D
Lesson learned, always backup first just in case.
Oh yeah, do I need to reflash the kernel?
Hey guys i succesfully DID IT! :DDDDDDDD i am soooo happy! just a couple questions. ... i want my phone to have that ics theme. how? and also for another update can we update the phones fps somewhat? when i drag down the notification bar it "steps"
hiredbyskill
