Wanda
- May 6, 2010
- 1,454
- 133
- 0
I'm having an issue installing the "stock fonts" from the optional downloads section. I'm installing the rom through ROM Manager and everytime I try it - the font doesn't change, and somehow my marketplace and astro apps get deleted.
I'm installing it through the "install ROM from SD-Card" option in ROM Manager... and deleting delv cache before the install. Any ideas?
Edit: FYI just got into this ROM flashing thing today, so I still don't totally know what i'm doing.
I'm going from memory here but, I wouldn't do it from ROM manager. Do it manually from recovery...90% percent of the time when something doesn't flash right its because I was using ROM manager.
Make sure the .zip you want to install is on the root of your SD card. To navigate the menus in recovery use the volume up and downs to scroll, the power button to return to previous menu, and the optical track button to make selections. Hold down the power button to bring up the menu of options like power off, reboot etc...go to reboot, reboot to recovery. Go to "install zip from SD". Once there scroll through the items on the zip until you find the fonts .zip, select it, tell it your sure, and let it do its thing. Once it's done use the power button to go back to the menu with reboot system and reboot. You should now have the old fonts installed.
