[ROM] Warm Z TwoPointTwo [RLS1][2/23/2011] Re-Engineered Nightlies [3/12/11]
and good looking out with the advice!! i wasnt tryin to circumvent you, i was just offering some extra help just in case.
Nah dude, I was totally kidding...not upset in the slightest.
thanks for all the links but wanda helped me first, thanks wanda. im going to flash over this nightly pretty soon today, but 1 more question b4 i full whipe and flash cwm, i dont have to change anything or file namkes do i just add that zip to my sc, then full wipe then flash cwm2 then rom?
Nope, you don't have to change the name of the zip or anything. Just make sure you've got the CWM 2.5 zip on the root of the sd AND the ROM. Get into recovery, flash the CWM zip first, then without rebooting flash the ROM. Reboot and enjoy.
Reactions: zero neck
i flashed it perfect and just flashed the rom rebooting now.... thanks for the help man want to try their wifi.. i like the sence alot more than cm7 but alot of pros about that rom too
Sweet pretty much set up with warmz now.. only thing is the playon app doesn't work. That's a real bummer I have to use playon to watch my Netflix on my phone. I'm going to make a nandroid and just switch between his one and cm7. I love this rom alot
dinc warmZ 2.2
So I flashed the row by the rules posted and I'm having problems. It is constantly restarting sense and apps just close when I try to use them. Also when I'm trying to enter my Google account on start up it just keeps starting over. I have to go through that process several times. Any one have a clue what's going on.
Did you wipe data, cache and dalvik cache?
What version of cwm did you flash the rom with?
yes im using the file the reverts me back to clockwork 2.5.1.2
All I can think for you to do is go back into recovery and do a full wipe of data then cache then dalvik, then wipe data and cache one more time. Them flash the rom using 2.5x cwm and you should be good
dinc warmZ 2.2 via tapatalk
I'd agree. Go back to 2.5 with the .zip from the previous posts and THEN do your data wipes...in fact, just to make sure, wipe it twice. Then flash the ROM, then reboot.
Once you get it running, it really is a nice ROM, the trouble is its kind of a pain to get up and going.
Ok i'm starting to get frustrated!
i've been wanting to give this rom a try for a while now but it just wont work!
ok i've tried a few different things:
1-tried to install RLS1 using correct link for CW3 which is what i'm running.(no go)
2- then tried installing latest nightly by replacing META file(posted by Upstreammiami) to work with CW3.(no go)
3- now im tryin to install lastest nightly using the file that temp gives you CW2 and have both on root of sd card. i wiped everything 2 times both on CW3 and CW2. still on the splash screen and have been for about 10 min now and counting.
*also on the 1st two bullets i also let the splash screen stay for 15 to 20 min. and i also wiped all 3 things at least 2 times before attempting to flash rom.
any ideas or advice?
I had nothing but problems flashing this rom. Successful after a few tries tho so don't get down. This is what I say you try this time.
Reload your nandroid of your previous rom.
Then make sure you have clockwork mod 2.5x on your SD. Go back a few pages you'll see me trying to find it. Wanda said its.in the bottom of this link. Go there and get cwm 2.5 if you already haven't.
Then dowload the nightlies. Make sure you download the incredible one as in the nightlies page there are two different devices
Put both on the root of your SD.
Go to clockworkmod app on you device then boot into recovery.
Wipe data, cache, dalvik, data again, cache again.
Then flash cwm2.5 (your screen will now be I'm green font not orange.)
Then flash warmz for incredible.
Then reboot when it finishes
Wait maybe 2-3 minutes ay white HTC screen then the warmz splash will appear and maybe about another 2min there you should be in.
Reactions: Don Veneziano
Can I flash a custom kernel on this rom from another rom or is that a no no??
Wow your never going to believe this! I just realized I downloaded the wrong nightly (not for the incredible) Haha such an idiot I can't believe I totally over looked that.
D-Inc CM7 via Tapatalk
Lol... Something like that happens to everybody at least once! I'm glad you got everything sorted out.
@kaEfbaMl & @Wanda - Keep up the good work in here dude
-Via Tapatalk on my hINCm7
haha yea I'm going to give it another shot tonight and hopefully I get it all right this time. lol
EDIT: Got it working!! Thanks everyone for the amazing help!!!
That's why I had mentioned there were two devices in there. Honestly I did the same thing but downloaded the file on my phone and realized like 40% way through download the file name wasn't what I was reading the forums.. hahah. But I didn't flash wow so I guess flashing roms from another device won't broken your phone.
I'm glad that you got it working that's really good up here man. What do you like so far about this rom? What were you coming from?
I'm coming from CM7 and I'm a die hard fan of it because its my favorite ROM by far.
I wanted to give this rom a try because I wanted to play with sense 2.0 and I love it. Its really smooth and quick. The only thing is there isn't as much customization as CM7 but I think I've just been spoiled with them :-p The call quality is very clear too I've noticed except I feel like I was getting a stronger signal (more bars) with CM7 than with Warm Z. Maybe its just in my head. lol. The only other thing that bothers me is how i cant change the the dock bar too much. I liked how in CM7 i can change how many icons I wanted along with customize all the icons on bar.
But I'm reallly enjoying the sense and cant wait until (hopefully able to) they port sense 3.0 to our device.
pramanj96
