[ROM]Wintergreen
awesome. you like what i did? I tried to give it sorta a gingerbread look and feel while staying on froyo.
@dmrlook: It isnt as much programmers as people that know what the hell their doing. I am not one of them. I am surprised I even made the clock white. I was just playing around in services.jar and I f***ed something up and it turned the clock white, so i thought i might as well take advantage of that and I made the status bar black to match.
Glad you like it. It would be wonderful if someone compiled gingerbread or ics for replenish but apearantly it won't happen. I hope it does somtime soon though because even though you can theme it like another build it never will be.
If anyone likes my work and is willing to donate, please go back up to the original post and click the donate button. I do this during my own free time for the community. Please support me and keep wintergreen alive.
-GPOT
I was going to download this to put on my wifes phone, but it looks like the links are down. Any status on that?
Reactions: GPOT
actually u are right. theyre down for me too... I will check on the server when I get home
Okay, the links are back up. HTTPD was stopped. Everythings up and running now.
I sent my phone into a boot loop with the flasher :\ if this happens to anyone else, please let me know and I will look into fixing this problem. In the mean time if this DOES happen to you:
1. Reboot your phone
2. Right after you press the power putton to turn on the phone hold down the "U" key
3. Perform Factory Wipe/Restore and reflash your phone to your old rom.
I am sorry for any inconveniences this bug might cause
Problem solved. Only use the flasher with a 32 bit version of windows NOT as an administrator and if needed, compatibility mode for windows xp sp3.
Version 0.2 has been delayed a couple of days due to an OS crash. I will be back online ASAP. Until then please try to deal with any bugs and glitches in version 0.1.
Sorry! Modern Warfare 3 has kept me from finishing version 0.2. It is a really good game. However, I will release version 0.1 Final until I can find the motivation to give the rom a makeover.
u should have instructions to install ..i have the evo as my main phone but have a mint-condition replenish..would love to install this because this phone is goin to be my friends
Btw modern warfare 3 is great and addicting..u enjoy shootin them fkers.lol
Reactions: GPOT
Yes sorry, I just assumed everyone would download and run the executable. I will put instructions up on the original post right now.
no but the next one will
and the next one will probably be up sometime after winter break ends. I usually do my developing in the library during lunch and sixth period because i get bored but right now I choose MW3 over developing. don't worry, I won't dead end the rom though.
lil tip we tried including wifi tether in arearom the only place to put it is in data/local as it will not run and force closes in /system/app and if they do a factory reset wifi tether is gone so its hard to include unless you just put in the zip file with instructions on how to install it.
How long does it take to flash the rom to the phone? I've been going on 15mins now. Cmd promp says setting permissions......
Installing gbusybox.......
installing custom rom......
First time trying, does it usually take this long?
evitasari
