idbl_fanatic
- Jan 30, 2011
- 171
- 16
- 0
Grabbed, flashed, and stuck on the Android logo![]()
Same here..........
Wiped re-flashed, everything is fine
DO NOT PRESS THE ANDROID GUY. . Press the 4 corners and skip to the market where then you can put in your google info.
Why would you pay for a free app...?thanks im not paying for rom manager
how is the rom updates free?
Anyone know why my phone list in ROM Manager does not show LG Optimus One?
I downloaded the most up to date ROM Manager, 4.3.1.3 and it only lists:
Huawei Pulse Mini,
Dell Streak,
Huawei Pulse
Commtiva,
Geeksphone One
Spice MI700
Huawei Ascend
Huawei U8220
Something must be wrong, in the screenshots in the HowTo it shows tons of phones like Droid, Nexus One, etc.
I tried to scroll down, but it stops at the last one, Huawei U8220.
The scroll window bar on the right shows I've reached the bottom of the window.
Downloaded the software twice. Should I try a reboot or something?
you need to tell Rom Manager that youve already installed clockworkmod recovery, so it can update its lists and give you access to ROMs.
thats what i had to do, mine was doing the same thing.
there should be a "how to use rom manager" thread around here somewhere, it had some helpful pics.
once you actually tell rom manager that youve already installed clockworkmod (so it doesnt ask you to each time) then youll be able to browse roms for more phones.
again, this is pretty much exactly what i had to do becuase i had the same problem.
if it doesnt work, idk what to tell ya haha
Does anybody else have issues with this rom mostly fails to install apps from the market/amazon or even backups? Is there a limit to the number of apps you can have installed?
I have already googled for answers and tried the normal things (reboot/delete cache/wipe/ etc). Is there a setting that I have missed?
