[ROM][WIP][ALPHA][NS4G] oICSv43 | AOSP 4.0.3 (ICS)
Re: [ROM][WIP][ALPHA][NS4G] oICSv26 | AOSP 4.0.1 (ICS)
New update..
v26 available.. See the OP for change log.
Re: [ROM][WIP][ALPHA][NS4G] oICSv25 | AOSP 4.0.1 (ICS)
Anyone else having usb storage connections problems when connecting to a computer? (Both Linux and Windows). It says connected as media device on my device but it's really not. Been using clockwork to mount.
Just flashed v26 and no mounting problems with mine on my computer. Have you tried a reboot of the phone? One thing I've noticed with these ICS roms is right after install I've had to do a reboot or two to fix some random quirks and then they seem to go away.
I havent actually plugged in with 26 yet. Ill see what happens the next time. But i know what you mean. All my screen rotate stopped working even on the browser and i had to reboot to fix. Also gps wasnt working on 26 for me. I did a quick cache whipe with dalvik and flashed over again. If anyone has that problem
When I up dated to v26 I needed to go back in and clear and reload agps with GPS test
Sent from my Ice Cream Sandwich
I used GPS Tools and it worked for a little but then stopped. Got a link? I just did a full wipe and fresh install and not working. Got a market link for what you used?
Did 26 with a full wipe and it's rock solid... GPS seems fine... Been running all day without issue
Sent from my Nexus S 4G using Tapatalk
https://market.android.com/details?id=com.chartcross.gpstest
its still alittle slower than gb was but i'm chalking that up to the fact that its a port....
Hmm. I tried that one before you got back to me and it didn't seem to work. I used the one I had before and it fixed it again. After the full wipe and then restore it seems to working now longer periods of time. Not sure what the problem is.
Hope it's straightened out in the next few builds. Otherwise I'm going to have to go back to GB next week when I need to GPS. :(
GPS seems to be alittle flaky some people don't have a problem...some people have to cold start their GPS....some people can't get it to work at all
Ok. Google wallet update in the market. Anyone else getting the error that the package is not signed correctly?
I had some issues with GPS the other night. But they seemed to go away. Could just be because I live in Seattle and it was rainy/foggy.
However, something odd that I noticed is that my battery has drained to 44% after being off the charger for just under 5 hours ago. I haven't really done anything on it today than send a couple of text messages and tweets.
Other issue was with keyboard (both Android and TouchPal) not actually putting any texts in messages as I would type. Not sure if this is ICS-related or just my phone.
Im assuming the wallet app was tinkered with and resigned. Hmm.
Funny. I have problems with gps and this morning i wake up and my phone has a gps lock for no reason. Had to reboot to get it off.
Feel like it was a facebook thing.
I uninstalled Wallet with Titanium and then did a fresh install of it through the Market. Used it at the store with no issues.
Doesn't any have any idea what the issue is with the video effects crashing the app? Its pretty consistant even after a reboot.
Not sure why a feature like that would be on any developers fix list.
I'll give that a shot. Was thinking about it. Wasn't sure if Wallet would even install through the market after it being it was an OS Update thing only. Thanks for the head up.
Uh, I just tried the CM9 Kang because my GPS is still buggy on here. Same problem over there. Went back to stock for like 30 seconds. GPS worked fine. Just couldn't stay on GB. I'm back on this build again.
Edit: removed wallet with adb and installed from the market. Adding card failed. Retry worked. Seems to be working.
Re: [ROM][WIP][ALPHA][NS4G] oICSv27 | AOSP 4.0.1 (ICS)
New version is out.. v27...
Changelog in OP
dumpsterrentals82
