[ROM][WIP-ALPHA7][CM10 PORT] Jelly for Optimus V
Status
Not open for further replies.
Try switching your apns file to the one from cold as ice
Tried it its also in framework.jar I think in Cdmas.smali and I'm lost when I have to edit it
Sent from my LG-LS670 using Tapatalk 2
You can't edit the cdma file, with the one from ics, its WAY different code
Nonono not that I'm lost in editing the one in cm10 I'm gonna try to fix before I release next build
Zakman I just started using you ROM and its pretty kool :) Google now is this close to working. I hope you keep working on the ROM :) thanks :)
Reactions: Badboytoast
Hey. So I see moving apps to SD is bad.Does that mean apps that are already on my SD are going to be gone? Or are they fine.
Will update slimmed gapps tomorrow, with scrolling google now. But a warning gapps has gotten bigger. It's 56.1mb now.
I think I'm going to flash this on the old optimus v laying around. I rooted with gingerbreak last night and I'm gonna flash cwm today. Should I just flash this first or start with another ROM?
Edit: flashing!
Re-edit: flashed! And its awesome!
Sent from my LG-VM696 using Android Central Forums
Status
tsmtoolpro
